Trail braking and EBD
Old Aug 2, 2004 | 01:05 PM
John's Avatar
John
Default Trail braking and EBD
This past weekend at VIR-N was my first time on R-compounds, and with this upgrade comes new challenges. Since I am aware that I went pretty wide in the rear (275) and the car will understeer more with this setup, I tried to trail brake into several corners. On some corners I have no problem, but on a few, when I hold the brake as I turn in, I feel the EBD transfer all the force to the front outside wheel. The result is a small skid.
Any ideas on how to manage this issue?
Old Aug 6, 2004 | 08:14 AM
orhanz33's Avatar
orhanz33
sorry for the newbie question, but what's EBD and how does it work?
Old Aug 6, 2004 | 09:46 AM
John's Avatar
John
EBD = electronic brake distribution... the EBD modulator sends more pressure to the wheel that will stop the car the best...
Old Aug 20, 2004 | 10:07 PM
BigRich's Avatar
BigRich
I'm assuming there is very little we can do to disable the EBD. I had asked a dealer to find out (and I trust they did) and they said that it is impossible...maybe we can fool it with a different pad setup?!?
Old Aug 29, 2004 | 11:52 PM
Kolia's Avatar
Kolia
I tought (hoped) there were 2 levels to disable the electronics ?
Old Sep 20, 2004 | 04:16 AM
shmately's Avatar
shmately
This may be another issue. EBD dose'nt mess with be when I drift and there is no traction at all there. I think the EBD may be help me from spinning when at the limit of countersteer. I pull a red fuse in the engine bay to disable the abs.
Old Nov 10, 2004 | 03:18 PM
StaticCling's Avatar
StaticCling
John, did you ever get a fix for the EBD-Trailbraking issue?
I noticed it happening big time when I was at Putnam Park (IN) in a fast carousel. I think if I had been smoother and turned in slower it might have gone away. Maybe the car was just trying to tell me to be smoother.
Old Nov 11, 2004 | 06:52 AM
phoenixZ33's Avatar
phoenixZ33
Is the EBD a function of the VDC? I've never had an issue like that either on a track or autocross, on R tires. My car has TCS, not VDC. Supposedly there are ways to completely disable VDC.
Old Nov 11, 2004 | 02:21 PM
amolaver's Avatar
amolaver
Reading about EBD, it sounds to me like pulling the ABS fuse should kill it - I believe it uses the ABS actuators to accomplish its mission. By killing electrical power to the actuators, EBD should be knocked out of the picture.
Of course, no more relying on the ABS to save your bacon Threshold braking learning curve, here you come...
ahm
Old Nov 12, 2004 | 07:30 PM
03Z33's Avatar
03Z33
Once you get used to running without the ABS/VDC fuse it is impossible to go back It is the only way to take your car to the limit on the track. The ABS system will not allow you to trail brake, or threshold brake (especially if you run same size tires all around)
It's unfortunate that such a nice sports car has to disable the ABS/EBD system to be used on track. I have driven many cars that did not have such poor ABS systems (granted many of them are much more expensive).
Just be carefull not to flat spot those expensive slicks
Old Nov 23, 2004 | 09:27 PM
amolaver's Avatar
amolaver
Hey John - any update on whether pulling the fuse kills the EBD?
ahm
Old Nov 23, 2004 | 10:28 PM
03Z33's Avatar
03Z33
***UPDATE***
Disconecting the Bosch Yaw sensor under the center console (below e-brake) will disable bothe VDC/EBD without disabling the ABS! I have been running this for the past two weeks now and like it much better. I only pull the ABS fuse when on track now and need to be able to lock under brakes (brake drift).
Old Nov 24, 2004 | 04:19 AM
del105's Avatar
del105
15 f125
Originally posted by 03Z33
***UPDATE***
What warning lights do you get when you do this?
Old Nov 24, 2004 | 05:00 AM
John's Avatar
John
***UPDATE***
Good find! Can you provide us with photos of where it is exactly?
<- thinking of wiring in a switch for it somehow...
Old Nov 24, 2004 | 10:59 AM
03Z33's Avatar
03Z33
The VDC and Slip warning lights will stay on permanently.
A few others have mentioned adding a switch, but for me this would be pointless since I would never re-activate it...
I don't have a digi-cam but here is a step by step on how to disconnect:
(#2 phillips head screwdriver is the only tool I used)
1. Remove key from ignition
There are 5 screws to remove on the Z (only 4 on the G35C)
2. First two screws are on either side of console towards the rear, it helps to slide both seats all the way forward, and tilted to access these.
3. Next screw is under the ash tray (lift up) (the G35C does not have this one)
4. Next you will need to pull up gently on the shifter boot plastic cover... I do this by sticking my hand in the leather boot and pulling up until it clicks in a few places. (You do not need to remove the shift ****)
5. You should now see the last two screws below holding the center console in place. (Be carefull not to tear the electric ribbon for the heater controls on the Z and there is one electrical plug to unplug on the G35C if you have heated seats).
6. With the center console lifted up over your e-brake handle (pull the brake up high to make it easier to remove the center console) you will see there are two sensors: The one towards the rear is for the airbag (DO NOT DISCONNECT THIS ONE) The one towards the front (directly behind the shifter) is a black sensor with BOSCH sticker. This is the one you should un-plug. The clips for the plug are on either side of the connector. Secure the loose connector to avoid future rattles.
7. Replace center console reverse of removal.
Enjoy the much improved throttle and brake response of your car!
There is a small picture of the sensor on page 99 of the HyperRev Fairlady Z Tuning manual if you have this. It is the bottom insert on the Powerhouse Amuse article. You can purchase this "tuning guide" from many vendors but it is in Japanese.
Old Nov 26, 2004 | 05:20 PM
spdu4ia's Avatar
spdu4ia
so unhooking this sensor and the fuse (someone tell me which one) for ABS will disable almost all computer assisted driving?
would this be only recommended for the track and not the street?
were is the ABS fuse?
Old Nov 27, 2004 | 01:05 AM
03Z33's Avatar
03Z33
ABS fuse is the red 50 square fuse in the fuse compartment by the battery under the hood. This will disable pretty much all computer assist. I drove the car for over 2 years with this fuse pulled.
Disconnecting the Bosch yaw sensor will only cut traction control and VDC. This may be a better option if the ABS does not bother you as it may save your tires from flat-spotting when you lock up the brakes.
Old Dec 3, 2004 | 06:16 AM
Lateapex's Avatar
Lateapex
On my Enthusiast model, the fuse-box you refer to also has "ignition" (I think) on it, so I haven't tried pulling it... I thought, perhaps, the models without VDC were wired differently and I would be creating another problem if pulled that fuse. No?
Any help is appreciated, as I'm tired of the "state-of-the-art" brake control on my car going into ice-mode, or whatever, 2 out of 3 autocross runs.
Old Dec 3, 2004 | 07:41 AM
03Z33's Avatar
03Z33
I should have clarified that the above only applys to 2003-2004 manual 350Z models w/ factory VDC (Track, Touring, Performance models) and G35 Coupe (manual).
I have not had enough time with a base/enthusiast model or automatic to figure it out. I do know that the fuse we remove in the VDC equipped vehicles is not present in the base/enthusiast and auto cars, and the yaw sensor is also missing. Let us know what you can find.
Old Mar 23, 2005 | 09:52 AM
dank311's Avatar
dank311
I have a 05 base model Z, and for some reason i can seem to brake drift...Is this because of the ABS (since we dont have VDC)? I also looked for the ABS fuse and it is attatched to the ign fuse...if i pull the ABS, the igniition will be coming out also...so is there any other way to disable this, or get around all this?
Please help ASAP!
thanks,
Jon
