Audio Install complete... pics inside -->
Old 10-10-2002, 07:37 PM
SKiDaZZLe
Charter Member #34
SKiDaZZLe's Avatar
Default Audio Install complete... pics inside -->
ok, here is the rundown on the components:
- stock headunit (didnt care to mess with nav integration, maybe will swap with 8V Eclipse Pre-out in the future)
- Boston Acoustics RC620 (6.5" components in stock driver and tweeter locations) Driver required 1" spacer to clear window.
- Boston Acoustics FX6 (6.5" coaxials in rear stock locations) These rears are running off headunit power, since they dont need to much push.
- 2 JL Audio 8W3D6 (Dual 6 ohm voice coils, running parallel on each speaker, then parallel into AMP.. this gives 1.5 ohm total) These are in a custom enclosure, kind of like a stealthbox. The shop made 4 sides from MDF, then contoured the bottom with mold fabric and resin. it sits flush in stock sub location. Pics below.
- JL Audio 300/2 pushing the front Bostons. input signal from front signal from headunit. crossed over.
- JL Audio 250/1 pushing the subs. input signal from 300/2.
- 4 gauge power and ground for amps
- Dynamat extreme for doors and firewall thing.
all work done at Tweeter in Frisco...the most awesome installer... Patrick Riley, was a magician!!
here is the first pic (the front drivers)..
Attached Thumbnails Audio Install complete... pics inside -->-audio-install-010-small-.jpg
Old 10-10-2002, 07:42 PM
SKiDaZZLe
Charter Member #34
SKiDaZZLe's Avatar
btw.. i have 30 pics (1600x1200).. only going to attach a few descriptive ones...
this is the enclosure (upside down).. you can see mold which fits like a glove inside cubby.
Attached Thumbnails Audio Install complete... pics inside -->-audio-install-003-small-.jpg
Old 10-10-2002, 07:45 PM
SKiDaZZLe
Charter Member #34
SKiDaZZLe's Avatar
here is the cubby hole for sub and rear speaker.. all dynamatted...
Attached Thumbnails Audio Install complete... pics inside -->-audio-install-005-small-.jpg
Old 10-10-2002, 07:47 PM
SKiDaZZLe
Charter Member #34
SKiDaZZLe's Avatar
here is the enclosure with the subs installed...
Attached Thumbnails Audio Install complete... pics inside -->-audio-install-016-small-.jpg
Old 10-10-2002, 07:50 PM
SKiDaZZLe
Charter Member #34
SKiDaZZLe's Avatar
here are the amps.. we took out false bottom and mounted the smaller one on a piece of MDF.. then built a riser for the bigger amp, at the same angle...
Attached Thumbnails Audio Install complete... pics inside -->-audio-install-021-small-.jpg
Old 10-10-2002, 07:52 PM
SKiDaZZLe
Charter Member #34
SKiDaZZLe's Avatar
here we took the flase cover for the non-bose sub enclosure, cut out the center and wrapped in grille cloth...
Attached Thumbnails Audio Install complete... pics inside -->-audio-install-024-small-.jpg
Old 10-10-2002, 07:53 PM
SKiDaZZLe
Charter Member #34
SKiDaZZLe's Avatar
here is the install with its stealth look...
Attached Thumbnails Audio Install complete... pics inside -->-audio-install-027-small-.jpg
Old 10-10-2002, 07:55 PM
SKiDaZZLe
Charter Member #34
SKiDaZZLe's Avatar
here is everything exposed...
Attached Thumbnails Audio Install complete... pics inside -->-audio-install-030-small-.jpg
Old 10-10-2002, 07:56 PM
SKiDaZZLe
Charter Member #34
SKiDaZZLe's Avatar
close up of subs with cover... you cannot really see subs without flash...
Attached Thumbnails Audio Install complete... pics inside -->-audio-install-026-small-.jpg
Old 10-10-2002, 08:01 PM
SKiDaZZLe
Charter Member #34
SKiDaZZLe's Avatar
here are fuses for amps.. it runs through 2 grommets (sp?) made through firewall. they are on a custom piece of ABS, it is all really stealth with battery cover on. you can see huge wire loom (which has 2 4 gauge wires running through it.
Attached Thumbnails Audio Install complete... pics inside -->-audio-install-011-small-.jpg
Old 10-10-2002, 08:02 PM
SKiDaZZLe
Charter Member #34
SKiDaZZLe's Avatar
last pic...
this is a close-up of the fuses on the ABS panel.
Attached Thumbnails Audio Install complete... pics inside -->-audio-install-012-small-.jpg
Old 10-10-2002, 08:03 PM
Danimsta
Danimsta's Avatar
dude that looks super sweet!
GREAT INSTALL!!!!
Old 10-10-2002, 08:08 PM
aggie300zx
aggie300zx's Avatar
Looks awesome, but my question (didn't see you talk about this) is...how does it sound? Actually how does the two 8" sound? I have a similar setup but with the JL 10 in the hatch right now. Going to dual 8" was an idea, but decided to wait and just use a small box in the hatch. Would love to hear how it sounds. Are you going to the Z tour tomorrow? I'll be there. PM me.
Old 10-10-2002, 08:13 PM
nizl
nizl's Avatar
Very nice!!! Excellent, clean, tasteful install.
How much was the $$$ damage???
Old 10-10-2002, 08:14 PM
SKiDaZZLe
Charter Member #34
SKiDaZZLe's Avatar
sounds freaking incredible. fader is on FR3.
i like trance and techno, and it comes through so crisp. the installer mentioned the Z has a good stage, eventhough the drivers are not angled in... i think the strong tweeters helps bring the stage up.
the subs absolutely pound... when i put in oakenfold/ seaman CDs, it is so awesome,... when i put in rap cds, it punches pretty hard.
i dont need 12W7 performance, since i dont like that sound... the dual 8's work awesome for the Z.
m
ps, i might go to concert... still dont have any info on meeting place...
Old 10-10-2002, 08:16 PM
jtree007
Charter Member #53
jtree007's Avatar
Looks great...like others are asking how do the 8's sound?? also anyone know the approx size of the NAV box its self? Is it close to 1DIN or is ti bigger/smaller/deeper
SKiDaZZLe
Charter Member #34
SKiDaZZLe's Avatar
$3k with parts and labor.. went with initial qoute...
we (I ) changed the setup like 10 times. install took 5 days total.
a_p
a_p's Avatar
Very Impressive... I love the rich sound of Bouston Acoustic speakers..
if you don't mind me asking, what was the total cost of the audio components?
Old 10-10-2002, 08:23 PM
SKiDaZZLe
Charter Member #34
SKiDaZZLe's Avatar
about $2k for parts, $1k for labor...
m
Old 10-10-2002, 08:25 PM
aggie300zx
aggie300zx's Avatar
Well I'm not sure the plans either, but was thinking about parking in the big lot on the far side of the West End. There should be plenty of room by that time to find some parking. The only thing to think about as well is Friday is opening night for the Stars regular season. Give me a ring if you head down there....214.244.8985
Scott
Quick Reply: Audio Install complete... pics inside -->
