Will there EVER be a GOOD plenum that keeps the stock strut?
i just wanna know if anyone out there besides Crawford is ever coming out with a dyno proven plenum that posts nice gains and allows us to keep our factory strut bar.
i hope that isdunique comes out with the one he has talked about but i am beginning to lose hope. i definitely thought we would see it or another by now.
is there anyone else with one on the horizon?
Keep in mind that LSDUnique's is a totally new design and I think it replaces the upper and lower plenums (not sure). This will take a lot more R&D work, etc. We def. don't want something less than the best LSD can do. I will wait. Besides, I am holding off on things for the motor like plenums and cams, etc. until there is a perfect or near perfect solution for AF ratio and timing, etc through electronic engine management. That does not exist yet. When it does, it's party time.
While Crawford’s plenum (collector) mod is proven, it's definitely not 'stealthy". IMO, differential porting of the lower collector could offer similar benefits while maintaining the stock external appearance.
The whole point of the Crawford Plenum is that the stock plenum slopes down in the front to accomodate the hood and the stock strut bar, and therefore squeezed down the area that gets air to the front 2 cylinders. That is the problem that Crawford is resolving by creating more air for those 2 cylinders, with the taller plenum. There is simply no place for the stock strut brace to go. So you get Crawford's brace for $200. It is offset from the shock towers with heavy duty brackets. That is not a perfect solution, but it is about as good as it is going to get. Here's a pic.
The DW SC design integrates the SC into a redesigned plenum. This might make the engine breathe more evenly to each cyl, but that remains to be seen. A great idea IMO IF you are going FI.
Jeff - zland
Jeff - zland
I STILL don't understand why the plenum is so expensive... looks like all you do is cut off the front/top half the the plenum, replace it with sheetmetal, and weld it back together... am I missing something or is that hardly a $450 job?
Cutting, grinding, fitment, welding, powdercoat, clearcoat. Plus the upkeep of the custom jigs, plama cutter, welders, saws, grinders, etc.
