Bass Link installed in Factory Space!
Old 06-05-2003, 07:38 PM
joust75
joust75's Avatar
Default Bass Link installed in Factory Space!
Got the bass link to keep my four other infinitys company. As you can see it is mounted in the stock sub spot. Also we dyno matted the hell out of the area. It works.
Nice clean base and no rattles. I am a happy man.
At 200 watts, it aint overkill, but I dont need that much. Especially with a cabin this small!
Factory Cover purchased thru UltimateZ.com
Old 06-05-2003, 07:39 PM
joust75
joust75's Avatar
mas
Old 06-05-2003, 07:40 PM
joust75
joust75's Avatar
As you can see it is bolted to the metal above and is facing down.
Old 06-05-2003, 07:42 PM
joust75
joust75's Avatar
For those considering this, I highly reccomend it! Excuse me everyone, I am going for a drive!
PS Even the installers were impressed with how good it sounds!
Old 06-05-2003, 08:25 PM
Mr.Blue
Mr.Blue's Avatar
I'm Jealous. I had the same idea going through my head. I am glad to see that it worked out well for ya. Did you Dynomat only the sub compartment or did you do the entire area including the rear speakers?
Old 06-05-2003, 09:39 PM
Jordanz
Jordanz's Avatar
Man thats exactly what i am going to do. Why did you mount it down, could you rig up a bracket to point the sub toward the opening, just an idea. Exactly how much dynamat did u use
Old 06-05-2003, 11:25 PM
joust75
joust75's Avatar
We used one $69 pack of dynomat. I am unsure of the square footage. I only had the enclosure wrapped. That was all I needed. I am not running a four channel amp. through the speakers and tweets I am just doing my sony 52watts per channel. I dont need an eardrum blasting showcar!
The unit is mounted facing down because the position is acoustically superior to angling it out. The mount position also has the most level surface.
Cosmetically it might suck that it is not angled out but IDGAF
If you are considering doing this, I reccomend you do it the same way! Dont assume the installer will take the trouble to test how it sounds best.
Again this is not the route to go if you like impressing people in 'the hood'. It is the way to go if you want a nice clean all around system. Don't worry, It may be civilized, but it still thumps!!
Old 06-06-2003, 06:55 AM
Raistlin
Raistlin's Avatar
That is an awesome idea, couple questions.....
What size (or model) is the Bass Link?
What brackets did you use to mount it? (size..etc)
Where did you buy them?
Thanks
Old 06-06-2003, 09:27 AM
mark350
mark350's Avatar
Right on!!! something else to add to my future plans list.
Old 06-06-2003, 11:00 AM
toykilla
toykilla's Avatar
Thanks
Basslink is made by Infinity.
It is a subwoofer unit with a built in amplifier. All you need for it to work is to run RCAs or speaker wires to the unit and power source (direct from battery)
It comes with all necessary hardware for mounting. It sounds amazing for the size (when tuned right )
Old 06-06-2003, 11:19 AM
Stone Z
Stone Z's Avatar
Thumbs up
Hell yeah....this is exactly what I was wanting to hear. I'm glad someone finally took the plunge and tested it out. The only thing I was concerned about was the sound quality, and apparently that's not an issue. This is definitely going to happen now.
Thanks a lot!
Old 06-06-2003, 01:15 PM
Raistlin
Raistlin's Avatar
I knew it was made by Infinity, I just wasn't sure if there were different models with different size woofers.
Thanks for the 411 though
Old 06-06-2003, 01:42 PM
Stone Z
Stone Z's Avatar
Did you use all four mounting brackets or just the two in front?
Old 06-06-2003, 02:28 PM
ADMAN
ADMAN's Avatar
Coolness. You beat me to it. I was going to do the same thing. I
just hadn't gotten to pulling the panel and seeing if the BassLink
would fit. I had a feeling I wouldn't have enough room to stand it
up the right way. As you said, it probably wouldn't have sounded
as good anyway.
Good job!!! Thanks for the much awaited photos too!!!
ADMAN
Old 06-06-2003, 03:47 PM
joust75
joust75's Avatar
All brackets were used to mount the Baselink! I was all set to have a custom fiberglass box made then installed in that area, but I said F*K it. It was literally an impulse decision.
I had been thinking about it but I went in to Circuit city not knowing what to do. I just pointed at the thing and said : PUT THAT IN MY CAR!
Thanks for the complements. it was my pleasure to post the pictures!
Added bonus: Theives will not see the woofer, but even if they know about it they will need a good 2 hours to tear apart that section of the car! That thing is in there!
Old 06-06-2003, 03:55 PM
ADMAN
ADMAN's Avatar
Originally posted by joust75
Added bonus: Theives will not see the woofer...
Unless they're on here right now reading your post...
Thanks again,
ADMAN
Old 06-06-2003, 03:56 PM
Stone Z
Stone Z's Avatar
Lightbulb
Circuit City uses a new brand of deadening made by Tsunami. It's supposed to be a little thicker and stick better than Dynomat. From the price, it looks like you used the *door* package which is 12 sq. ft.
Old 06-06-2003, 04:00 PM
Stone Z
Stone Z's Avatar
joust75
Did you have them install the Bass Level Controller?
Old 06-06-2003, 11:48 PM
joust75
joust75's Avatar
That is exactly right! Someone has done his research!
Old 06-06-2003, 11:56 PM
joust75
joust75's Avatar
joust75
I had no need for this. My HU is freaking awesome, I have a base control just like all stereos and a subwoofer level control on the sound menu along with the treble, base, balance and fade. The unit plugged right into the Sony HU. No wiring tricks or splicing necessary. A clean easy install!
BTW, I highly reccomend this model. It matches the Z dash better than any other aftermarket HU. It is the Sony CDX CA810X XPLODE.
I posted some pics a while back, Ill try to find the link to the thread!
Quick Reply: Bass Link installed in Factory Space!
