Dyno Result for my Touring 6MT - 244.4HP/235.9 TQ
Old Jan 9, 2003 | 10:22 AM
iboost's Avatar
iboost
Default Dyno Result for my Touring 6MT - 244.4HP/235.9 TQ
Runs done today, 1/9/2003 at Cybernation Motorsports DynoJet in Ft. Lauderdale, Fl.
2003 350Z Touring, 6MT, approx. 4,525 miles.
Only modification is custom grounding kit. Everything else is stock. Runs done in 5th gear and topping out around 142.2 mph.
CONDITIONS:
27 feet above sea level
Two miles from Atlantic Ocean
Temperature: 70°F
Dew Point: 52°F
Humidity: 54%
Pressure: 30.02 inches and falling
I'm happy with the result. I took video too... it's not very interesting but I'll post it if anyone is interested.
Regards,
iboost
Old Jan 9, 2003 | 10:28 AM
markz's Avatar
markz
Default Very Strong Numbers
You must be very happy
Mark
91 300zxtt 400hp (SOLD)
Waiting for the 350z drop top
ACEMAN's Avatar
ACEMAN
Default How did you break the car in?
With all this talk about breaking the engine in. Did you keep it under the 4000rpm before 1200miles?
Old Jan 9, 2003 | 10:50 AM
iboost's Avatar
iboost
Default Re: How did you break the car in?
Actually... yes. I'm a little extra cautious, so I did drive under 4k rpm until 1,200 miles.
Then I changed oil & filter at 1,214 miles and drove it a little harder (no redlining yet) until about 1600-1700 miles.
After 1,700 miles I've driven it pretty aggressively.
I changed the oil/filter again at 3,000. Then switched from dino to Mobil 1 synthetic at 3,750. Hope this helps.
-iboost
Old Jan 9, 2003 | 10:59 AM
ares's Avatar
ares
Veteran
Originally posted by 3.0LV6
Seems like several people are getting the "spikey" dyno readings in the upper RPM range.
Also, your dyno numbers are inflated since they are in STD HP and TQ. If you correct them to SAE the numbers will be a good bit lower. (Most likely in the 230's depending on the weather conditions)
Just curious, how much difference was there b/w your 1st and 2nd dyno run?
he gave conditions, he was basicly at sea level, and Im not sure what SAE temp and pressure is, but Id assume not far from what he has there.
Old Jan 9, 2003 | 11:26 AM
roberto350z's Avatar
roberto350z
is dynojet the one where you take off the wheels and get higher readings.
Also, are ALL the numbers typically posted really in SAE, or is this SAE vs. STD a bunk statement?
Old Jan 9, 2003 | 12:29 PM
iboost's Avatar
iboost
I took it upon myself to find out what the SAE values might be. I'm assuming I'm doing this math right. I'm using the Dyno Correction Calculator found here
Air Temp = 70 F
Pressure = 30.02 in
Vapor Pressure = 0.39 (derived from Air Temp and Dew point using this vapor pressure calculator
Dyno Correction Factor = 0.977
Given that,
244.4 * 0.977 = 238.7788 HP
235.9 * 0.977 = 230.4743 TQ
Assuming all my math (and calculators) were right, then these are the likely SAE corrected #'s.
Also, just found this site too: Clint Pohler's Forced Induction Dyno Horsepower Corrector Just enter 0 psi as boost pressure. Gives dyno correction factor all one one page.
Well... I paid to get 2 dyno runs in 5th gear. The first dyno run, 001, was done in 3rd. I mentioned this to the tech and he immediately redid the run in 5th (run 002). He then started to unstrap the car from the dyno where I had to stop him and tell him that I still had 1 more run.. in 5th... which is what I wanted & paid for.
Long story short, I had to talk to one of the head guys at the shop, restrap the car, position it on the dyno again and retest. I have the chart for the 3rd run here -- I'll scan it when I get a chance and I'll post it as well. The printer wasn't working to print the 3rd graph, so I told the tech to let me mess with the computer for a while.
Well the tech left and I eventually managed to print out the dyno chart which I completely goofed... you'll see why in a bit... I put the curves in the wrong places.. oops. It was my first time playing w/ the WinPep program and I didn't realize my error until AFTER I printed it.
The dyno chart for the first run, 001, was never printed. We thought that we DID print it, but turns out the tech printed out the 002 run twice, thinking one was the 001 and the other the 002 runs. :\
I also took a blank 3.5" floppy to save my runs to, but I goofed up when saving them because it didn't save them to the disk correctly. *sigh*
Dynojet is a chassis dyno where the wheels stay on the car and the wheels are positioned atop a rotating drum.
SAE vs STD? I'll let someone who can provide a better technical answer than me explain.
Regards,
iboost
Old Jan 9, 2003 | 12:36 PM
iboost's Avatar
iboost
Default My 3rd run
As promised, run 003 which I completely botched up by putting all the curves in the wrong spot. Isn't that the ugliest graph you've ever seen?
I'm assuming that these #s were lower because of an already heat-soaked engine?
-iboost
Old Jan 9, 2003 | 01:23 PM
apex locator's Avatar
apex locator
no, thats a dynopack
Old Jan 9, 2003 | 07:45 PM
uro279's Avatar
uro279
Question WOT?
Sorry guys, but I have tried to figure out what this means without success. What does 'WOT' mean?
Old Jan 9, 2003 | 09:59 PM
iboost's Avatar
iboost
The only way to know for sure, it to either copy the Dyno.002 file off the PC where the dyno was done and load it up in WinPep at home or have them pull up your dyno runs again on the PC at the shop and reprint the graph with the SAE correction factors used.
Not a bad idea. I'm going to head to the shop tomorrow and see if they still have my runs saved on disk. I remember saving it to their local HD myself... I just wonder if its still there.
Regards,
iboost
Old Jan 10, 2003 | 10:09 AM
iboost's Avatar
iboost
Exclamation Update on Dyno #'s
Just got back from the shop and was able to download all 3 dyno runs. Here they are for your viewing pleasure. You will need to download the Dynojet Run Viewer. Here are a few places to get it:
http://www.dynojet.com/downloads.shtml
http://www.powercommander.com/viewer.shtml
The version I'm running is 7.0.7.14
Now to the raw data files (right click and Save As...)
Run 001 : Done in 3rd gear
Run 002 : Done in 5th gear
Run 003 : Done in 5th gear
Summary:
Run # : HP/Torque [SAE] @ Temperature, Pressure, CF):
Run 001 : 227.33 HP / 215.64 TQ @ 70.55 degrees F, 30.06 in. Hg, CF = 0.97
Run 002 : 238.25 HP / 230.44 TQ @ 75.04 degrees F, 30.07 in. Hg, CF = 0.98
Run 003 : 232.56 HP / 229.70 TQ @ 77.15 degrees F, 30.10 in. Hg, CF = 0.98
For those who just want graphs... well, I can provide that too.
Right click and Save as...
All 3 runs on one chart, Dynorun.001, Dynorun.002, Dynorun.003
There's a wealth of information to be obtained from playing w/ the Dynojet Runviewer program. I like it a lot. Next time someone else goes out to dyno there car, take a diskette and save your runs on them and post 'em here. I'm curious as to what other people's results look like in the runviewer program.
Regards,
iboost
Old Jan 10, 2003 | 02:41 PM
iboost's Avatar
iboost
Question
On the first two runs that were done back to back, VCD/TCS was OFF. The car was then turned off for a while before the 3rd run was done. On the 3rd run VCD/TCS was ON. Any idea if this makes any difference whatsoever? The tech said it might....
-iboost
Old Jan 11, 2003 | 09:09 AM
350Z33's Avatar
350Z33
Nice numbers! And good work taking care of your car to get its full potential.
Man I miss sunny Ft. Lauderdale.
Old Jan 12, 2003 | 10:27 AM
iboost's Avatar
iboost
Originally posted by Imprezd
Question why do you guy dyno in 5th gear? Isn't their a tremendous about of load on the engine in 5th gear?
Imprezd~
I personally did so because running the engine in 5th would produce a graph with more detail as opposed to running it in 3rd or 4th. Why? Simply because 5th would take a longer time to wind out before reaching redline therefore giving the dyno more data to plot.
6th is out of the question because the Zs top-speed limiter would more than likely prevent the engine from reaching redline.
Others mention that running it in 5th is best because it is the Z's 1:1 gear, providing the least amount of drivetrain loss, therefore resulting in clearer/truer #s. Some also mention that other factors such as overcoming the rotational inertia of the drum hinders your dyno pull MORE in lower gears as opposed to higher gears. *shrugs* I didn't study physics in college. Its not my area of expertise.
As for the load on the engine in 5th: Although I can't prove it, stop-n-go traffic in the city may actually be harder on your engine/tranny than a 16sec/pull in 5th on a dyno. I wouldn't worry too much about it.
Regards,
iboost
