Dyno Results: 235.6rwhp
Old Jan 4, 2003 | 09:05 AM
McDan's Avatar
McDan
Default Dyno Results: 235.6rwhp
Dyno'd my 6-speed 350Z today.
First run - slightly heat soaked engine
229.8 rwhp & 231.0 rwtq
Second run - after letting cool in front of fan
235.6 rwhp & 237.0 rwtq
Car again is a 6-speed, was dyno'd in 5th gear (1:1) on a DynoJet dyno. 1740 miles on the car. Air temp ~53deg. I mixed in 2 gallons of 100octane on approx 6 gal of 92 octane Amoco to help reduce any possibilities of knock, but did not drive a round much to allow computer to compensate for it. I followed break-in procedure till about 450miles, then gradually eased into full throttle runs by 600miles or so, then open season after that...
Second run numbers were about what I expected (though I hoped to be in the 240's).
I'll post a pic of the graph monday when I can scan it in.
-Dan
Old Jan 4, 2003 | 10:31 AM
zogan's Avatar
zogan
Default Re: Dyno Results: 235.6rwhp
-Dan
Does anyone know what the average results are (stock)
Attached Thumbnails Dyno Results: 235.6rwhp-navspac.jpg
Old Jan 4, 2003 | 10:54 AM
dougrace zs's Avatar
dougrace zs
We got 243 on a dyno jet but the car had 4500 miles on it, probably need to let them break in a little longer.
Old Jan 4, 2003 | 11:49 AM
McDan's Avatar
McDan
The guy at the dyno shop said he typically see's LS1's and others increase their rwhp by 8-10 or so after about 6000-10000 miles. So yes my engine is still a baby, but has a decent amount of miles to get some baseline numbers on. I need about 100lb.ft. more torque to be satisfied....
Old Jan 4, 2003 | 03:03 PM
2003z's Avatar
2003z
At balanced performance in buford ga, right? I got 242 stock there.
Old Jan 5, 2003 | 04:52 AM
dougrace zs
Yep you got it must have seen my Z down there. Were working on some intake mods at Sunbelt also.
Old Jan 5, 2003 | 05:01 AM
alphaz's Avatar
alphaz
Hey Doug,
I wish I had know you were at Sunbelt. I was at Balanced on Friday . I would have stopped by to say hello.
How is it coming with the intake mod ? I am really interested in this .
Rick
Old Jan 5, 2003 | 05:31 AM
dougrace zs
The car was actually down there a couple of weeks ago. They were working on moving the strut bar so we can make the intake plenum taller. Could take a couple of months to get everything done and tested but I will keep everybody updated. Good to here from you.
Old Jan 5, 2003 | 12:19 PM
12SecZ's Avatar
12SecZ
Thumbs up Yep Yep
My guy uses the a Dyno Jet too and he has said the same thing about the numbers, he said about 5k miles though for LS1's.
In fact a friend gained .3 at the track in his famous "Orange Crush" WS6 stock just by driving it a year, no mods!
Old Jan 8, 2003 | 06:34 AM
McDan's Avatar
McDan
trying to post it...
Old Jan 8, 2003 | 06:54 AM
McDan's Avatar
McDan
Allright, this 200k maximum size limit is driving me nuts! I can't post it. I'll try a little bit more later.
Old Jan 8, 2003 | 07:00 AM
McDan's Avatar
McDan
Attached Thumbnails Dyno Results: 235.6rwhp-dyno.jpg
Old Jan 8, 2003 | 08:04 AM
blackS's Avatar
blackS
...I think anything above 235hp is good, especially at such low mileage. Also keep in mind that at different locations, conditions are different. Thus if you are comparing your dyno at a high altitude vs a low altitude, or temperature, or moisture, or type of dyno, etc they are not exact comparisons...
Old Jan 8, 2003 | 05:01 PM
2003z's Avatar
2003z
also, which wheels do you have? I have lightweight 18lb enkei's.
Old Jan 8, 2003 | 06:04 PM
McDan's Avatar
McDan
Stock 17" wheels. Stock everything else, except the addition of 2 gallons of race gas.
Old Jan 9, 2003 | 11:00 AM
blackS's Avatar
blackS
Originally posted by Mirakaski
Blacks,
Actually most dynos take those variables in consideration a spit out SAE corrected numbers. It makes everything equal.
...yes, but SAE calculations are not going to be exact, as you cannot account for every single variable with 100% accuracy. Also keep in mind that most people expect to see above 240whp to be 'satisfied', that is only around 5whp different from what a lot of people are getting... that is around a 2% difference (.02) factor...that could very easily be made up or taken away on small differences in the rounding of your decimal points in SAE adjustments for example...what I am trying to get at is that, as I originally stated, is that if you are around 325whp then you should not be dissapointed at all....
silverbullet_Z
NA Builds
24
Nov 14, 2015 02:52 AM
seagrasser
Oct 11, 2015 03:27 PM
NissanZcrazy
Sep 23, 2015 07:59 AM
