How to: Cleaning the MAF
Old Jan 4, 2004 | 03:53 PM
VandyZ's Avatar
VandyZ
Exclamation How to: Cleaning the MAF
If you are experiencing rough idle after the installation of a CAI, Popcharger, or any other oiled filter replacement, here is a easy and relatively safe way to clean oil off the MAF.
1. Remove MAF tube from whatever setup you run. (This step is not needed if you are very careful and can complete step 2 with out the assembly touching or knocking anything.)
2. Un-screw MAF assembly from MAF tube.
3. Spray access hole with Electrical Parts Cleaner. Allow to dry out (10-15 minutes). Repeat as you wish. Make sure it is dry as the liquid can damage MAF if present on startup. Also Electrical Parts Cleaner is very flammable.
Old Jan 4, 2004 | 04:36 PM
MyZ4U2C's Avatar
MyZ4U2C
Great post VandyZ...thanks for the tip!
Old Jan 4, 2004 | 04:42 PM
jesseenglish's Avatar
jesseenglish
There are a couple of different types of electronics cleaners. There are some types that are corrosive. Make sure it's the type to use on sensitive electronics components. It will say on the can that it's good for sensitive electronics, ie PC boards etc.
Good post.
Old May 11, 2005 | 06:01 AM
maximumsportZ's Avatar
maximumsportZ
I Wish the pics worked.
What do you guys think about this cleaner?
http://www.caswellplating.com/permat...mcleaners.html
Old Nov 16, 2006 | 10:58 PM
Roger V's Avatar
Roger V
Can you buy this cleaner at radio shack?
Old Nov 17, 2006 | 05:47 AM
gqong's Avatar
gqong
You can buy an MAF cleaner from Pep Boys or some auto stores. It is made by CRC. It dissolves very fast.
Old Dec 15, 2006 | 12:37 AM
jondimellow's Avatar
jondimellow
what is the access hole? does anyone have pictures?
Old Dec 15, 2006 | 08:34 AM
hrj_1985's Avatar
hrj_1985
where r the pics?
Old Dec 15, 2006 | 09:33 AM
350Zenophile's Avatar
350Zenophile
You don't need to disconnect the battery first?
Old Dec 15, 2006 | 09:45 AM
Eazzy's Avatar
Eazzy
+1 ---I use it, get mine at Napa
Old Dec 15, 2006 | 02:09 PM
rocks's Avatar
rocks
rubbing alchohol works good with a coffee filter as it wont leave lint like a qtip. I used to clean heads on vcrs like that back in the day heh.
Old Dec 15, 2006 | 05:18 PM
jondimellow
what kind of screw driver is that u need to unbolt the MAF from the housing?
Old Jan 11, 2007 | 07:32 AM
SilverJDMCoupe's Avatar
SilverJDMCoupe
You need a Torx 20 to remove the bolts that hold the MAF in. I am actually going to go and clean mine on my lunch break, I'll let you guys know if it helped.
Old Jun 11, 2007 | 04:36 PM
illjim69's Avatar
illjim69
works!
used it on the MAF of my old Maxima (vq35de) and while i noticed no power "gain", the car idled much better.
jim
Old Jul 27, 2007 | 12:06 PM
Darshu's Avatar
Darshu
They're not regular Torx bolts though. They're the tamper proof kind. You can get something like this to remove them:
http://www.amazon.com/pc-Tamper-Proo.../dp/B0009U6ABE
Old Aug 18, 2007 | 06:08 PM
MyZ4U2C's Avatar
MyZ4U2C
Mine has phillips head screws.
Old Apr 14, 2008 | 08:47 PM
ladyzed's Avatar
ladyzed
+1 mine too
Old Apr 14, 2008 | 09:32 PM
surfcity40's Avatar
surfcity40
great advice. reminds me of folk
Old Apr 16, 2008 | 08:32 AM
BakaN20's Avatar
BakaN20
Can someone reupload the pictures. I have just been getting boxes with red x.
Old Apr 16, 2008 | 09:07 AM
DavesZ#3's Avatar
DavesZ#3
I've been trying to get the OP to restore them for the past year with no luck.
