How-To Repair Stuck / Broken Window Motor ...
Old 05-22-2008, 09:42 AM
VO...
Administrator
VO...'s Avatar
Default How-To Repair Stuck / Broken Window Motor ...
Yet another "How-To" I thought I'd create for the masses of people like myself that have had the similar problem of either one or both of your windows acting funny, getting stuck, won't roll up, or won't roll down.
This is a How-To on how to clean your OEM window motor. The window motor I had to clean was on the passenger side. I don't know exactly how long this cleaning will last, but I can tell you it works. I'm creating this thread for the members like myself who want to give it a shot and see if it works before biting the bullet and dishing out $160 or so on a new motor. Either way, if you decide to just replace the motor, this tutorial will lead you in the right direction.
EDIT: A couple months after I cleaned the original motor, it failed again. I replaced it entirely with one of the refurbished motors listed below. It's 10-1-2009 now and it's still working like a champ. So do yourself a favor and replace it entirely. The cleaning appears to be a temp fix.
EDIT: It's now 6-13-2014. The driver's side replacement motor is still going strong. No problems. I had to change out the passenger's side motor. I used the Cardone motor for the passenger's side also. It's running like a champ. Remember, buy them from O'Reilly Auto Parts. They offer a 2 year warranty.
EDIT: I had time today to locate the replacement motors for each side at the 2 most common auto parts dealers. This is for the individuals who wish to buy a new motor.
Links updated 6/13/14. NOTE: Even if a link no longer works, the part numbers remain the same
Autozone:
Driver's side: Part# 47-1377
http://www.autozone.com/autozone/par...artNumber=true
Passenger's side: Part# 47-1376
Advanced auto parts:
Driver's side: Part# 471377
http://shop.advanceautoparts.com/p/c...377&showTitle=
Passenger's side: Part# 471376
http://shop.advanceautoparts.com/p/c...376&showTitle=
O'reilly Auto Parts:
http://www.oreillyauto.com/site/c/de...1200&ppt=C0356
Edit - Nov 2014
Originally Posted by kwadell
By the way, for those new to replacing the window motor I did build on VO7848 instructions and wrote up a mega guide. Here is the link to the PDF:
http://static.ibsrv.net/autocomm/Con...ep14update.pdf
The following 4 users liked this post by VO...:
apeman1213 (09-29-2015), blue08 (04-20-2021), dboyzalter (07-24-2015), spdterence (10-29-2019)
Old 05-22-2008, 09:46 AM
VO...
Administrator
VO...'s Avatar
Default Day 1...
I decided to make this a 2 day job since I like taking my time, maticulously avoiding mistakes.
The first day I decided to just remove the outer door panel completely, in preparation to actually dissasemble and clean the motor the next day.
Here's a shot of the door prior to dissasembly....
Old 05-22-2008, 09:47 AM
VO...
Administrator
VO...'s Avatar
First things first. We start by removing the brushed aluminum door handle finisher. My tool of choice was a butter knife. It's slim and works better than a flathead screwdriver...
Old 05-22-2008, 09:52 AM
VO...
Administrator
VO...'s Avatar
Next we want to remove the armrest panel....
The following 3 users liked this post by VO...:
dboyzalter (07-24-2015), zimjig (05-06-2016), Zquicksilver (09-10-2015)
Old 05-22-2008, 10:08 AM
VO...
Administrator
VO...'s Avatar
Next step we want to unclip the switch panel completely, remove 2 bolts holding door handle in place, pull door handle off, then remove switch panel from the door....
After the switch panel is removed, unscrew the 2 bolts located in the following picture...
Old 05-22-2008, 10:15 AM
VO...
Administrator
VO...'s Avatar
Next step we must remove the hidden screw behind the door lever....
Old 05-22-2008, 10:17 AM
VO...
Administrator
VO...'s Avatar
Next we remove the entire outer door panel. Follow the instructions captioned on the pictures....
Old 05-22-2008, 10:25 AM
VO...
Administrator
VO...'s Avatar
Once the outer door panel is removed, you'll have to detach the door lever cables in order to disengage the panel from the door....
Old 05-22-2008, 10:30 AM
VO...
Administrator
VO...'s Avatar
Default Day 2....
Alright, here's the hard part. Here's the layout of the inner door panel and sequence of bolts you must remove. Before you begin removing bolts, duct tape the window first. *DO NOT SKIP THE DUCT TAPE. IF YOU DON'T HAVE ANY, GO BUY SOME!
EDIT: 3/15/13 ...I replaced the driver's side motor yesterday with the window stuck in the down position. If the window is in the up position, follow the duct taping procedure, but if it's already in the down position you can still replace the motor easily. Name:  IMGP3703.jpg
Old 05-22-2008, 10:38 AM
VO...
Administrator
VO...'s Avatar
Before removing the door panel, undo this plug...
Here's some extra pics with illustrations to show you what to expect when you start unbolting everything...
Old 05-22-2008, 10:40 AM
VO...
Administrator
VO...'s Avatar
One last thing before opening up the door panel and exposing all the internals...
Old 05-22-2008, 10:43 AM
VO...
Administrator
VO...'s Avatar
Here's some internal shots of the door once you've pulled the door panel aside...
Old 05-22-2008, 10:45 AM
VO...
Administrator
VO...'s Avatar
Bright idea, then fail...
Old 05-22-2008, 10:47 AM
VO...
Administrator
VO...'s Avatar
Before I discovered you need to remove the motor entirely from the spindle, this is how things went down...
Old 05-22-2008, 10:50 AM
VO...
Administrator
VO...'s Avatar
After unsucess with my first course of action, I decided to remove the motor from the spindle.....
Back shot of the spindle/motor assemble....
A few shots of what needs to be cleaned...
Old 05-22-2008, 10:52 AM
VO...
Administrator
VO...'s Avatar
I don't care what ya've heard. Use this stuff or something similar to do the cleaning. I'm all about working smarter, not harder....
A few shots after everything is cleaned up...
Old 05-22-2008, 11:07 AM
VO...
Administrator
VO...'s Avatar
Putting everything back is fairly easy. Having your wife or someone help you hold the panel when reattaching it helps a bit, but you can certainly do it by yourself if need be.
Remember to attach the motor to the back of the panel first, then loosely fasten the two bottom 12mm track nuts next. You can loosely attach the two top track bolts after that, then scew in all the remaining 12 panel bolts. Be careful screwing in the 12 panel bolts. They strip easily.
After the inner door panel was back on, I plugged the switch panel in to test it. Just as I thought, when using the "auto up" feature the window rolled up then half way back down.
All I had to do to fix this was perform the "reset" procedure. I've attached a copy of the reset procedure as thumbnails.
You will need to have access to the reset switch. Here it is...
After I completed the reset procedure. Everything worked just fine. I'm hoping this is a long term fix. Only time will tell now.
I hope you guys enjoyed this tutorial.
That is all, OK I'm finished.....
Attached Thumbnails How-To Repair Stuck / Broken Window Motor ...-04089-1.jpg   How-To Repair Stuck / Broken Window Motor ...-04089-2.jpg
Old 05-22-2008, 11:26 AM
JCat
JCat's Avatar
I can't tell you how timely your post is. My window (motor) just ****.
THANKS FOR POSTING THIS !!
Old 05-22-2008, 11:27 AM
VO...
Administrator
VO...'s Avatar
No prob man...
Old 05-22-2008, 11:42 AM
j.arnaldo
j.arnaldo's Avatar
You're a REAL buddy, doing what you did for us, Zed partners! Lamentably, between my job, caring after my 89-year-old mother, & spending quality time with my wife & 2 kids, well, I'm gonna have to pay, either for the clean-up or to get a new motor! Fail...At any rate, I appreciate your selfless action in
trying to help us save a few bucks! The farthest I can go, regarding maintenance on my "Z", is oil changes, tune-up & general stuff (cleaning the K&N with the recharger, battery maintenance, install brake pads, etc.) THANKS, anyway!
Quick Reply: How-To Repair Stuck / Broken Window Motor ...
