Cusco RS – opened up (lots of pics!!)
Old Feb 20, 2008 | 08:12 AM
first350's Avatar
first350
Default Cusco RS LSD – opened up (lots of pics!!)
post this in the autoX forum...but realized it's probably better served here:
Getting this installed today (too busy to do it myself)…it comes as a 2-way 100%lock, so I switched it last night to a 1.5 way, 80% lock. The manual that came with it was in all Japanese, and while I’m ½ Japanese, I don’t come close to understanding the written language…luckily there were pictures with #’s (like 100% / 80%/ 60%, or 1-way, 1.5-way, 2-way) – so it wasn’t too hard to figure out what to do.
Lock %:
The plates that have notches on the outside lock onto the housing, the plates w/ notch on the inside lock onto the gear portion. These 2 types of plates have grooved surfaces that are opposed to each other. (so by alternating them, you get the most amount of friction – 100% lock….by coupling some of the same type of plates together, you can get less friction  80% or 60%)
1, 1.5, 2 way:
The gear portion in the middle of the housing can be switched around to work as different types…it was fairly easy to look at the manual’s pictures and set it up to be a 1.5 way.
Here’s some pics (I always like to see lots of pics before I do a project...so here's all of mine!)
After opening the case, the internals just slide out.
The 2 different plates
Making sure it’s correct
Old Feb 20, 2008 | 08:35 AM
JDSMotoring's Avatar
JDSMotoring
Vendor - Former Vendor
Nice...let us know how you like it after installed
Old Feb 20, 2008 | 09:52 AM
gothchick's Avatar
gothchick
Very nice. You should maybe put this in the DIY section as well. Would help a lot of folks~ :-)
Old Feb 20, 2008 | 10:46 AM
first350's Avatar
first350
I just have to find a place to do figure-8's for 30 minutes! That's the rec'd break in procedure...
Old Feb 20, 2008 | 01:28 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
that thing looks noisy
Old Feb 20, 2008 | 01:48 PM
Lawn Dart's Avatar
Lawn Dart
Wow! That is really interesting. I am suprised that the discs have so much texture.
Old Feb 20, 2008 | 03:25 PM
daytona350z's Avatar
daytona350z
actually it isnt
mine is set up 100% 2 way and all it does is scrub the tire when making tight turns.
Old Feb 20, 2008 | 05:08 PM
kramykram's Avatar
kramykram
Originally Posted by daytona350z
actually it isnt
+1
Old Feb 20, 2008 | 08:39 PM
OH6 G35's Avatar
OH6 G35
Where do you go and do figure-8s for 30 minutes??
Good question...
Also, great DIY with pics!
Old Feb 21, 2008 | 07:15 AM
first350's Avatar
first350
Good question...
I was aq bit worried about this, but luckily I'm running an autoX practice next saturday ...so I'll show up a bit early, do my figure-8s, then change the diff fluid.
*I know a few large empty parking lots around the Seattle area, but lately police have been cracking down really hard on street racing / drifting...I'd rather not have to mess w/ them
Old Feb 22, 2008 | 04:46 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Cusco has no specified break in procedure
Old Feb 22, 2008 | 04:47 AM
Z1 Performance
Former Sponsor
when properly setup up for the conditions, and the right fluid used, it is not intrusive at all actually. Mine makes 0 noise, no inside tire scrubbing, it is absolutely seamless
Old Feb 22, 2008 | 05:24 AM
first350's Avatar
first350
even if they don't specify a break-in procedure, what's the best way to drive it at the beginning? I was just going off of what most ppl had been saying for clutch type LSD's...if the 30 min figure 8s is not needed, then all the better! (I was worried that 10 minutes into it, I'd )
Old Feb 22, 2008 | 05:26 AM
Z1 Performance
Former Sponsor
There is no break in needed per my conversations with Cusco. It might have to do with the springs, I am not sure...but I was happy to hear it as well! Install, drive as you normally would, then swap the fluid out in about 500 miles
Old Feb 22, 2008 | 05:57 AM
first350's Avatar
first350
WOW - that's great news . Thanks so much for checking!!!!!!!!!!
now I get to go drive it
Old Feb 25, 2008 | 12:49 PM
first350's Avatar
first350
Got the Z back and decided to do about 10 minutes of figure-8s and put some extra miles on it too, then I changed the diff fluid last night (super dirty!).
In all, I love this cusco LSD! Taking some familar roads, I found that I could start accelerating much sooner than I had been.
noise: At slow speeds (parking lot speed) the inside wheel can be heard skidding on tight radius'd turns, but I don't hear the LSD clutch making any extra noise...at speed, I don't hear anything extra (but my car is fairly loud as is, so it may be making noise and I'm just not hearing it )
Old Feb 25, 2008 | 02:21 PM
Lawy'dU's Avatar
Lawy'dU
Me want one.....!!!!! After finishing suspension, this will be my next mod.
Old Feb 25, 2008 | 04:29 PM
first350's Avatar
first350
so far I'm loving this cusco RS...I have an autoX this coming Saturday - can't wait to really see what it'll do!
Old Mar 26, 2008 | 03:03 PM
BenchTT's Avatar
BenchTT
How did you do?
Old Mar 26, 2008 | 04:56 PM
first350's Avatar
first350
Originally Posted by BenchTT
How did you do?
it was canceled....there's been some issues w/ our normal lot that we use - haven't been to an autoX yet ! Next event is April 6th (1st SCCA series event...wish I had some practice on the new diff and the tires...but either way, I'm just excited to get out and drive!)
