Haltech Platinum Review w/dyno numbers!
Old Nov 25, 2007 | 07:36 AM
ForcefedZ's Avatar
ForcefedZ
Thumbs up Haltech Platinum Review 700rwhp!?!? Well Almost:-) pg 3
Well, I finally got a chance to install and tune a Haltech Platinum on my 350Z yesterday. Overall the unit works very well, installation is a breeze, and the VTC worked flawlessly.
The only changes to the car was the exhaust and EMS. Having the ability to control the VTC will make a huge difference when tuned correctly. Dyno number 103 was what my car was making at the last track rental/meet at Mason Dison, if you compare that to the current setup (run 153, same boost levels) it yielded me nearly 130ft/lbs of torque at 4400rpm. That's a difference that even your "seat of pants dyno" will pick up
Congrats to Injected Performance for offering the community another capable PNP EMS solution.
-Ray
Attached Thumbnails Haltech Platinum Review w/dyno numbers!-hpems.jpg   Haltech Platinum Review w/dyno numbers!-vtc.jpg
Old Nov 25, 2007 | 07:40 AM
booger's Avatar
booger
Awesome Ray !!!!
Did you tune this your self ?
Old Nov 25, 2007 | 07:48 AM
ForcefedZ's Avatar
ForcefedZ
Originally Posted by booger
Awesome Ray !!!!
But of course I honestly bought it just to see how well it worked, and well it works. Every tuner has their favorite EMS, I just wanted to check this one out first hand.
Old Nov 25, 2007 | 07:49 AM
Blackbird CPV35's Avatar
Blackbird CPV35
wow! i bet it feels great making more power with less boost
Old Nov 25, 2007 | 10:00 AM
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
WOW! Thats some good numbers! Good tune!
Old Nov 25, 2007 | 11:03 AM
Alberto's Avatar
Alberto
Cranky FI Owner
You have a Revup? Impressive you picked up so much power up top peak over before. And I love the fact that your HP stays flat until 7500rpm's, that is a GREAT powerband for the track.
Old Nov 25, 2007 | 11:19 AM
rcdash's Avatar
rcdash
Nice tune no question - congrats. May I ask what EMS and exhaust you had before and which exhaust you switched to? I assume this is a Greddy TT? Can you provide any insights into your tune of intake vs. exhaust vtc?
Old Nov 25, 2007 | 12:35 PM
eagletanggreen
Got Track!!!!!
Man!
Those Greddy turbos just have best power band.
Old Nov 25, 2007 | 12:56 PM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
Ray, congrats on the numbers and tune - I wasn't sure that you ever got around to installing it Thanks for posting up your findings, and let me know if you need anything.
RCDash / Alberto, I believe he is non-revup, and was using AEM previously.
Old Nov 25, 2007 | 02:21 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
wow...that powerband is absolutely disgusting.
Old Nov 25, 2007 | 02:40 PM
Julian@MRC's Avatar
Julian@MRC
Nice!!did you play with the VTC much to achieve those gains?Or was it from leaning it out, smoothing it and adding some timing?
Looks Great!!
PS Hal@IP, yo never emailed me what we discussed, hit me up..
A
Old Nov 25, 2007 | 03:38 PM
ForcefedZ's Avatar
ForcefedZ
I have an 2003 so it's a non-revup engine. The peak gains up top are mostly do to the exhaust change. It should be interesting to see what it will trap now
Old Nov 25, 2007 | 03:49 PM
ForcefedZ's Avatar
ForcefedZ
The last EMS on the car was an AEM EMS, I never got the VTC to work correctly however it can be done (I think SP's version of the AEM works correctly with out modding the cam)
I had and Apex-i exhaust system with 2.5" Y section from the downpipes. I had used the stock flanges that are pretty smalI when I made the 2.5" setup. This time I made the Y section with 3" flanges and tubing that join to a single 4" exhaust system we made. It seems to be working really well.
Old Nov 25, 2007 | 04:30 PM
ForcefedZ's Avatar
ForcefedZ
Looks Great!!
A
I messed around with the VTC for about 20 runs. The VTC is what brought the torque up in lower rpm ranges. It can be a bit tricky to get dailed in. The power increases up top are from the exhaust system changes. The AFRs are about the same, and I was running lower ignition advance then on my previous tune.
Old Nov 25, 2007 | 05:16 PM
rb26ina240's Avatar
rb26ina240
-Ray
does the ecu retain the same factory failsafes for the DBW system
Old Nov 25, 2007 | 05:35 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Wow-Im about to come down for a tune damn that is great work!
Old Nov 25, 2007 | 05:42 PM
UnderPressure's Avatar
UnderPressure
The DBW system is completely controlled by the Nissan ECU. The Haltech has no effect on the DBW system.
*yet*
Old Nov 25, 2007 | 05:56 PM
ForcefedZ's Avatar
ForcefedZ
Thanks. We can stick your car on my DJ whenever you're ready
Old Nov 25, 2007 | 06:04 PM
rb26ina240's Avatar
rb26ina240
*yet*
so its kinda like a piggy back?
Old Nov 25, 2007 | 06:10 PM
ForcefedZ's Avatar
ForcefedZ
The unit runs parallel with the factory ECU. It also can run in a pass through mode similar to how the UTEC works.
