NA Project Part II with Forged Performace NA built motor
Old 08-30-2007, 05:17 PM
rednezz
rednezz's Avatar
Default NA Project Part II with Forged Performace NA built motor
Well after trying the NA route and failing...I decided to try it again but this time with a NA motor built by Forged Performance. The motor is built with Cosworth high compression pistons. I will be using the Cosworth heads off my other attempted build with the same 272 intake and exhaust cams. If all goes well I should hopefully have the motor installed and running by next weekend and dynoed after a full break in.
Sharif--thanks for all the help!
Attached Thumbnails NA Project Part II with Forged Performace NA built motor-fp3.jpg   NA Project Part II with Forged Performace NA built motor-fp2.jpg
Old 08-31-2007, 07:13 AM
Machupo
Machupo's Avatar
going with the FCon?
Old 08-31-2007, 07:16 AM
Kwame
Kwame's Avatar
Cool, Good Luck.
Old 08-31-2007, 07:22 AM
Fingers
Fingers's Avatar
Are you going to try the cosworth plenum or do you have anything already done with the intake side of things, and how high are you planning on reving to.
Old 08-31-2007, 08:20 AM
rednezz
rednezz's Avatar
I am going to take my car and get a tune from UpRev. They can adjust the VTC angles for me to get more power down low from these cams.
At this time I will use the stock plenum with a MD 5/16 spacer. I plan to do the Cosworth plenum probably sometime this winter. I plan on reving to 7600 rpm for now.
Old 08-31-2007, 09:20 AM
THE TECH
THE TECH's Avatar
Can't wait to see the results.
Old 08-31-2007, 10:44 AM
Resolute
Resolute's Avatar
+1^
I love to see the NA engines getting more popular. First Ritchie's Nismo engine, then Jeremy's high compression job, then Adam's awesome build, now yours. I'm excited to see the final results.
Will
Old 08-31-2007, 11:03 AM
ZLadie2000
ZLadie2000's Avatar
what are your power goals?
Old 08-31-2007, 11:13 AM
failsafe306
failsafe306's Avatar
What type of fuel will you be running? Or are you going to have different maps for pump and race?
Old 08-31-2007, 11:14 AM
VO...
Administrator
VO...'s Avatar
Nice!
Old 08-31-2007, 11:15 AM
n1sm0r
n1sm0r's Avatar
Are you doing anything about the crank rotating assembly (i.e. blueprinting, balancing etc).
What compression ratio are those pistons?
Old 08-31-2007, 11:38 AM
rednezz
rednezz's Avatar
I am shooting for 300 rwhp. Anything over I will be super excited.
I will be using pump gas. Don't think the price for race fuel versus possible gains will be worth the expense. I may try it just to see.
The block was built by Forged Performance and included the balancing and blueprinting.
The pistons are 11:1 compression. I am using the Cosworth head gasket as well with L19 studs.
Old 08-31-2007, 11:44 AM
NA&CH
NA&CH's Avatar
Good luck.
Chris
Old 08-31-2007, 12:00 PM
philude
philude's Avatar
sounds great, keep us informed with lots of pictures!
Old 08-31-2007, 12:43 PM
failsafe306
A little nitrous later down the road could be fun on a built high compression motor
Old 08-31-2007, 12:48 PM
Sharif@Forged
Forged Performance
Sharif@Forged's Avatar
That engine looks a lot better in your shop...instead of ours.
Glad everything arrived safely, and best of luck with the build-up. Keep us all posted, with how those high duration Tomei's work out for you!
Old 08-31-2007, 02:02 PM
350Z84
350Z84's Avatar
Sweet....Hope you hit the 300 club with the N/A. I've been trying to find out, but has anyone done a stroked N/A build?
Old 08-31-2007, 03:42 PM
Z1 Performance
Former Sponsor
Z1 Performance's Avatar
coming soon
Old 08-31-2007, 03:44 PM
AWDBall20
AWDBall20's Avatar
Good Luck with your build...NA Builds...keep em coming!
Old 08-31-2007, 04:39 PM
Audible Mayhem
My350z
Audible Mayhem's Avatar
i need to do another NA build and hit some big numbers...
maybe soon when i get some more sponsors!!
Quick Reply: NA Project Part II with Forged Performace NA built motor
