Need some help concerning Motordyne spacer
Old 07-19-2007, 09:08 PM
Mast3rShak3
Mast3rShak3's Avatar
Default Need some help concerning Motordyne spacer
Im kinda a noob at this but i have an 06 z. Ive noticed the spacers come in different sizes which is best/most common to use? ALso the website the best place to buy? thanks.
Old 07-19-2007, 09:25 PM
VisionaryRacing
VisionaryRacing's Avatar
It really depends on if you want to use your strut bar or not. I would recommend using the 5/16th Iso Thermal spacer if you want to use your strut bar.
We carry them as well, just shoot me a PM if you have any more questions
-Kevin
Old 07-19-2007, 09:29 PM
Blazemaster
Blazemaster's Avatar
the most common is the 5/16" version since it's the cheapest and the bigger ones offer comparable gains. With your 06, which is a rev-up motor, might want to look into the MREV2+spacers combo.
Old 07-19-2007, 09:49 PM
Mast3rShak3
whats this mrev2 you speak of?
Old 07-20-2007, 03:40 AM
Reality350
Reality350's Avatar
^search is your friend!
google "motordyne".. Then grab a coffee and start reading, you wont be disappointed.
Remember to get the MREV2 + 5/16th spacer combo, you wont regret it.
You could also PM hydrazine for more info, hes a very helpful person.
Also you have many forum sponsors who sell this product, I purchased from partshipperdave.
Cheers,
Old 07-20-2007, 08:47 PM
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Hydrazine's Avatar
+1
If you have a 06 manual transmission Z you have a REVUP engine. In this case definetly get the MREV2 with the spacer.
It costs more than just a spacer but the combination also makes much better gains.
If for example you could only afford one or the other (spacer or MREV2) then get the MREV2. It will make a minimum of 15HP in the midrange. You can always add the spacer later for better top end performance.
But don't start with just a spacer only. A spacer (by itself) on a stock REVUP lower collector doesn't do anything. The spacer must be used on a non-REVUP engine or a MREV2 for it to work... So if you can only do just one, do the MREV2. It will still make good gains. Add the spacer later. Its easy to add on too.
Old 07-20-2007, 11:07 PM
Mast3rShak3
So if i get the spacer right now it wont do anything? No hp gain? is that what your saying?
Old 07-20-2007, 11:20 PM
Mast3rShak3
I know that hp doesnt stack. So what exactly happens when i put all these mods together? for exmaple exhaust plus popcharger plus a spacer?
Old 07-21-2007, 05:10 AM
Hydrazine
Hydrazine's Avatar
Yes. That is correct.
Old 07-21-2007, 05:20 AM
Hydrazine
Hydrazine's Avatar
HP clearly doesn't stack if your car is running lean. But I have tested all the Motordyne mods on many, many different cars. Many that were fully stock and many that were highly modified.
In all cases, the plenum mod gains have always been the same as long as the engine has adequate fuel.
And typically you won't need any kind of engine management or reflash untill you add a lot of mods.
A plenum mod, pop charger and exhaust should be just fine. When you add test pipes to it, you may or may not begin to run lean. (it varies)
If you then add headers to the intake, plenum, exhaust and test pipes you are more likely to start running lean. After the addition of all of these mods the next phase of modification is the ECU. This is done with either engine management piggy back or a reflash.
Tony
Old 07-21-2007, 07:32 AM
Mast3rShak3
I have the nismo exhaust and a popcharger do you think i should the spacer? Will i notice anything is it worth it?
Old 07-21-2007, 08:01 AM
Hydrazine
Hydrazine's Avatar
Are you manual or auto?
manual = revup
auto = non-revup
Old 07-21-2007, 08:23 AM
Mast3rShak3
i have manual but i kinda dont want to buy the rev add on for 500. Just the iso thermal spacer 4/16
Mast3rShak3
i have manual but i kinda dont want to buy the rev add on for 500. Just the iso thermal spacer 5/16
Old 07-21-2007, 08:48 AM
jason350z
jason350z's Avatar
Originally Posted by Hydrazine
+1
man i wish i new this before!! i installed the 5/16 spacer on my 06 rev up. after installing it i didn't notice any gains. so i guess i should get the mrev2. how much hp would the combination between the spacer and the mrev2 give me. ??
now what if i get the mrev2 and a new plenum. i'm desperate for hp and none of the mods i've gotten seem to do anything but make the car louder
after installing both i'll need a new strut bar right? which one will give me enough space?
Old 07-21-2007, 08:50 AM
Mast3rShak3
I read something like 15hp but in the newest issue of import tuner it said possible 20hp.
Old 07-21-2007, 10:06 AM
Hydrazine
Hydrazine's Avatar
You can see the Import Tuner dyno test results of the MREV2/spacer in the dyno section of our website. It always does at least 15HP 18TQ in the upper midrange. In many cases it does 20HP 30TQ. Results typically vary within this range.
You can always use a plenum on the MREV2 as well, but in any case you have to start with the MREV2 for any of the spacers or plenum mods to work on a REVUP engine.
Old 07-21-2007, 10:45 AM
jason350z
jason350z's Avatar
i just order the mrev 2 . i have the 5/6". i read some was able to keep the stock strut bar. my question is will i need a new one or ont????????/
Old 07-21-2007, 04:39 PM
Hydrazine
Hydrazine's Avatar
The 5/16" spacer will fit with your stock strut bar. In fact, keeping the stock strut bar was the primary design goal of that size spacer.
Old 07-21-2007, 06:31 PM
jason350z
jason350z's Avatar
correct but mean the spacer plus the mrev2. the spacer is intalled and it fits fine but i order the mrev2 and i'm wondering if both will fit with the stock strut bar
thanks
Quick Reply: Need some help concerning Motordyne spacer
