2007 Altima engine Start/Stop button project
Old Apr 30, 2007 | 05:20 PM
Greg'Z33's Avatar
Greg'Z33
Default 2007 Altima engine Start/Stop button project
Well I like the S2K start button but decided why not keep my 350Z "all Nissan"? On a whim, I decided to buy the 2007 Altima engine Start/Stop button assembly, part number 25150-JA00A. It lists for about $30.00 and I got it cheaper than that at my local dealer 'cause they like me . I disassembled the switch to see what pins were for the switch contacts and various LED's. I can use a similar set-up as the S2K switch as far as the relay, but since the button clearly says it'll not only START but STOP the engine, this throws a little more R&D into the mix. I'm going to have the LOCK LED wired to the car's factory anti-theft LED on the dash so that it'll flash in sync with it. The ACC and ON LED's will be wired to light according to ignition key position, of course. The backlighting of the button and "ENGINE" underneath the button will be tied into the HAZARD button backlighting LED so that it'll brighten/dim with the rest of the dash lights. I'm going to try and get it wired up this weekend. As far as placement, well with the large chrome trim ring, real estate 's pretty tight on the console of my '06 6MT so that's why I chose this particular location. I did not test fit the console back down into place to check for clearance yet but I know it's going to a little tight as far as depth of the switch assembly (although it doesn't appear as deep as the S2K switch).
Stay tuned.......
Old Apr 30, 2007 | 05:33 PM
n8vz's Avatar
n8vz
sounds like a good mod. keep us posted
Old Apr 30, 2007 | 05:37 PM
PWSHHOCKEY44's Avatar
PWSHHOCKEY44
cant wait to see it done
Old Apr 30, 2007 | 06:39 PM
97supratt's Avatar
97supratt
This is pure genius wow. Let us know exactly what you do. Thanks
Old Apr 30, 2007 | 07:56 PM
Voboy's Avatar
Voboy
damn awesome! I always wanted to see the nissan starter intergrated in the Z.
Old Apr 30, 2007 | 07:59 PM
JDMFairladyZ33's Avatar
JDMFairladyZ33
Kicka$$ man ...please do a DIY when you finish. The Z community will love you for it!!
Old Apr 30, 2007 | 08:14 PM
Asian Invasian's Avatar
Asian Invasian
looks good keep us updated.
Old Apr 30, 2007 | 08:16 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
looks clean, not my style but good work anyway.
Old Apr 30, 2007 | 11:02 PM
97supratt's Avatar
97supratt
How much would it cost to make it exactly like the altimas where you sit inside the car with the keys and you can turn the car on.
Old Apr 30, 2007 | 11:31 PM
hndumafia's Avatar
hndumafia
if you could figure this out, with the wireless keys, girls everywhere would show you their *****.
Old May 1, 2007 | 06:19 AM
MustGoFastR's Avatar
MustGoFastR
Interesting. I'd like to see if you can get the "stop" feature to fuction. Still a bit elaborate, IMO for a setup where you still have to use the key. At least the S2K and otehr buttons like it just have the one function, like a race car start button. Looks good where you have it mounted, though. Good luck with it.
Have you tested the LEDs? I have a feeling it's not going to be as simple to wire it up as you think. With only 5 pins, I'm not sure each LED has it's own lead; they may be controlled by a circuit board in the unit.
Old May 1, 2007 | 07:23 AM
97supratt's Avatar
97supratt
Well I really do like boobies.
I'll look into this, most likely it won't work because nissan has the immobilizer in the key for the ECU.
Old May 1, 2007 | 08:10 AM
Greg'Z33's Avatar
Greg'Z33
I've bench tested the LED's and there are eight pins, not five. I *think* I can get the STOP function to work; if not, oh well.
Old May 1, 2007 | 08:31 AM
THE TECH's Avatar
THE TECH
Another cool project Greg.
Old May 1, 2007 | 08:36 AM
PikesPeakZ's Avatar
PikesPeakZ
Subscribing
Old May 1, 2007 | 08:42 AM
deviljon's Avatar
deviljon
by putting the button there, wouldn't it be pretty easy to accidentally press the stop button while driving?
Old May 1, 2007 | 08:43 AM
MustGoFastR
Oh, ok; cool. I couldn't immediately see the other pins in the pic. Should be fairly straightforward, then, on the lighting; not sure about the STOP feature.
Old May 1, 2007 | 09:01 AM
Greg'Z33's Avatar
Greg'Z33
Not really; the button has a pretty hard tactile feel to it and actually requires some effort to push it down.
Old May 2, 2007 | 07:08 AM
drumma022's Avatar
drumma022
It would be nice to integrate the antenna for the altima keyfob so you can eliminate the key switch all together
Old May 2, 2007 | 07:12 AM
Greg'Z33's Avatar
Greg'Z33
Yeah, it would be nice but that's beyond the scope of my intentions (or abilities) with this set-up; it's more for just the cool factor and because no one else has done it before.
