burning oil?
burning oil?
Just got my first oil change done this past Wednesday. The dealership put in 10w30 Mobil1 Synthetic. Car had 1,300 miles on it. Now when I start it, after being parked overnight, it burns oil. After about 1 minute, the blow-by stops. Car is a 2006, only 2 months old, and completely stock. Never been on the highway, until Friday night, and didn't run any higher than about 75-80mph... if that makes any difference.
Any ideas? Thanks.
Any ideas? Thanks.
Any ideas? Thanks.
Any ideas? Thanks.
John
Now when I start it, after being parked overnight, it burns oil. After about 1 minute, the blow-by stops. Thanks.
If you see vapor from the tailpipe at startup, that's water vapor. And if you see black droplets from the tailpipes, thats condensate coated with unburned hydrocarbons ("carbon").
The only way I know to determine blowby is with a gauge and leakdown test.
bill
He's getting rid of whatever metal shavings in the engine from break-in. Its an okay thing to do.
Well, how do you know you are burning oil? Do you smell it? Do you see it "L" on your dipstick? Did you check your dipstick level when you got your car back from its oil change initially? Are you following the break-in procedures?
I have an 06 Rev-up and not encountered any oil issues. Had the car since Feb 06. Over 8k miles now.
Originally Posted by antennahead
Forgive me, I don't mean to sound stupid here, but how do you know there's blow by in the first minute? I am watching this carefully myself as my '06 is burning a little also.
John
John
Also, didn't blow out this morning. First time, since I got the oil changed, that it didn't do it. Dipstick still shows "Full" though.
Originally Posted by bailey bill
And you know that because...?
bill
bill
I can smell it, and my bro said I blew out a big cloud of white smoke when I started. He happened to be in the garage, when I started, and I smoked him out.
I hope you've done some spirited driving before this trip on the highway. Best way to break in a motor is w/ some "light abuse".
Originally Posted by Sean_350z
white smoke is simply moisture. burnt oil out the tailpipes has a blue tint to it and it's gotta be really bad to see it. Ever drive behind one of those late 80s Chrysler mini-vans that burns oil and double for mosquito chasers? You won't miss it. If it's slow you'll have to watch the oil level over at least a couple thousand miles of driving.
Well, the only "spirited" driving I did, was along state highways to go home one weekend, ran probably around 85-90 mph, at times. The highway trip was just an alternate route I took, just for shi*s and giggles. And to see what the car felt like, on the interstate.
For "spirited driving", high speed won't help so much as foot-to-the-floor high rpm through a couple gears to get rings to seat quickly. Engine needs some load on it.
Won't help now. You haven't done any damage but the best seating of the rings comes from some aggressive rpm as soon as possible in the engine's life. The few motors I've built in the past have had the cam broken in, motor checked quick for leaks, oil changed, and then had the snot beat out of them the first time around the block.
You should most certainly floor it occasionally though! While else drive something w/ a performance engine?
