Test Pipe SES Non-Fouler Fix... pics
Old May 28, 2006 | 12:44 PM
Blurr350z's Avatar
Blurr350z
Thumbs up Test Pipe SES Non-Fouler Fix... pics
Since installing my Labree test pipes, I threw an SES after about 50 miles. I didn't do the non-fouler trick at first because I thought there was a chance I wouldn't see the light (I have an '04, turns out it must be an '04.5 since I threw the SES). Went down to Pep Boys, spent 8 bucks on the two sets of non-foulers, spent about 15 minutes installing them. There were two sets you could buy, I think the Z takes the 18mm (the guy at the parts desk actually went and got a 350Z O2 sensor to see which size was correct).
Here are the pics of everything. Even though there are alot of threads about this already, I made one because none seem to have pics, and hopefully this thread will clear up any questions for future instals.
First off, for those who don't know, you need to buy TWO pairs of the non-foulers. One pair needs to be drilled out with a 1/2" drill bit (Most drills can't hold this bit, look at the pics of the drill I used... its over 30 years old). Once one set is drilled out, you take a drilled non-fouler and screw it onto the O2 sensor. Then take the NON-drilled one and screw it onto the DRILLED one. So the order goes, O2 sensor-->Drilled-->Non-drilled-->test pipe/cat. Once you go to do the drilling and everything, the order makes sense.
Attached Thumbnails Test Pipe SES Non-Fouler Fix... pics-non-fouler-012.jpg   Test Pipe SES Non-Fouler Fix... pics-non-fouler-011.jpg   Test Pipe SES Non-Fouler Fix... pics-non-fouler-001.jpg   Test Pipe SES Non-Fouler Fix... pics-non-fouler-002.jpg   Test Pipe SES Non-Fouler Fix... pics-non-fouler-004.jpg
Old May 28, 2006 | 12:47 PM
Blurr350z's Avatar
Blurr350z
more pics
Attached Thumbnails Test Pipe SES Non-Fouler Fix... pics-non-fouler-005.jpg   Test Pipe SES Non-Fouler Fix... pics-non-fouler-007.jpg   Test Pipe SES Non-Fouler Fix... pics-non-fouler-022.jpg   Test Pipe SES Non-Fouler Fix... pics-non-fouler-025.jpg   Test Pipe SES Non-Fouler Fix... pics-non-fouler-024.jpg
Old May 28, 2006 | 12:49 PM
Blurr350z's Avatar
Blurr350z
and more..
Attached Thumbnails Test Pipe SES Non-Fouler Fix... pics-non-fouler-026.jpg   Test Pipe SES Non-Fouler Fix... pics-non-fouler-027.jpg   Test Pipe SES Non-Fouler Fix... pics-non-fouler-028.jpg   Test Pipe SES Non-Fouler Fix... pics-non-fouler-021.jpg   Test Pipe SES Non-Fouler Fix... pics-non-fouler-013.jpg
Old May 28, 2006 | 01:26 PM
Zivman's Avatar
Zivman
Originally Posted by StarcraftBW
I'd like to pay you 60 dollars shipped if you can make for me 4 non-foulers ..... 2 for headers and 2 for TPs/Cats............
Thanks
You do NOT want to use these on your upstream sensors (the ones in your headers)
Old Jul 13, 2006 | 01:32 PM
Kenk2's Avatar
Kenk2
Professional
Exactly what I did with my system yesterday..
Old Jul 13, 2006 | 01:40 PM
Kenk2's Avatar
Kenk2
Professional
Old Aug 22, 2006 | 05:06 AM
DaytonaZ9's Avatar
DaytonaZ9
how do you get the O2 sensor to stay in is when you drill the non fouler, it is not threaded?? what did you use??
Old Aug 23, 2006 | 05:57 PM
Zivman's Avatar
Zivman
buy a set of nonfoulers and look at them, it will become more than obvious how this is done
Old Aug 26, 2006 | 09:42 PM
arodbrs's Avatar
arodbrs
Default i was told about 5 h.p. is this true or what......
can someone tell me what the gain in h.p. is with stock exhaust and test pipes????????????????
Old Aug 28, 2006 | 07:23 PM
Blurr350z's Avatar
Blurr350z
Horsepower gains? To the wheels its probly a little higher than 5. The thing is, you'll lose low end torque and gain high end power.
Old Sep 12, 2006 | 10:37 PM
Armitage's Avatar
Armitage
Anyone still selling these pre-made? I might be buying a set of Labree TP's and an Nismo exhaust so if I can get them before I go through with the purchase, that would be great.
PM w/ price if you do this.
Also, another question. If you do this non-fouler workaround, if your local DMV does ECU tests to check emissions as opposed to a sniffer, will this help you pass or should you have a set of stock cats sitting around for the test?
Old Nov 6, 2006 | 06:27 AM
ISMSOLUTIONS's Avatar
ISMSOLUTIONS
For FI test pipes - about 8-12 HP...depends on where you live, sea level, time of year, tuned or not...Rick
Old Nov 6, 2006 | 06:29 AM
ISMSOLUTIONS
The low end TQ loss, per our dyno's and tests for the FI resonated testpipes, is at 2100-2250RPM - a whole 150RPM of losspoint....so basically no loss at all.
Check out the stats at www.fastintentions.com
Rick
Old Nov 7, 2006 | 07:46 AM
HARRYPOTTER's Avatar
HARRYPOTTER
and this prevents the O2sensor from throwing a code?.....can this be done if you have the Turbonetics single?
Old Nov 7, 2006 | 10:51 AM
jasonsfa98's Avatar
jasonsfa98
I have a 2005 G35 Sedan 5AT with Crawford cats, JWT Pop Charger and Z-Tube, and an Altered Atmosphere plenum spacer. I started getting the SES light before I installed the plenum spacer. I can't help but think it's the Cats since I had so much trouble with them in the first place.
If I can get the code, will that tell me which O2 sensor is pissed off?
Old Nov 7, 2006 | 03:14 PM
ISMSOLUTIONS
Don't know if it will work...but for $10 what's there to loose really..
Old Nov 7, 2006 | 03:19 PM
deezz's Avatar
deezz
Quick highjack: What exactly are the benefits of testpipes?
Old Nov 8, 2006 | 12:36 PM
Zexy's Avatar
Zexy
Yes it will should 100%
Old Nov 8, 2006 | 02:35 PM
ISMSOLUTIONS
A more freely flowing exhaust = more power an more sound.
Old Nov 8, 2006 | 02:44 PM
pss350z's Avatar
pss350z
I put non resonated TPs on my Z yesterday. I have to say it was a really bad idea cause now I'm all paranoid about cops smelling the stink of my car. Now all I can think about is getting rid of these for some HFCs. IMO TPs are not worth the meagre gains.
