Iridium Plug Benefits?
Old May 28, 2006 | 09:35 AM
OP Z's Avatar
OP Z
Default Iridium Plug Benefits?
Is there any benefit to using iridium plugs on a stock engine? Thanks.
Old May 28, 2006 | 01:01 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Yes, they last longer, and require less energy to fire. Iridium claims they last twice as long as platinums. You could probably go 100K miles with Iridums on an NA car. Make sure to get the standard heat range plug, vs. the one step colder that many of the FI people prefer.
Old May 28, 2006 | 01:23 PM
TiPIACE's Avatar
TiPIACE
good thread, my bro bought some denso iridiums for his Cooper S and said he noticed an improvement at higher rpm - just the car was smoother
i figured its just a placebo like grounding wires
he went one step colder, any reason why we cant do the same on a bolt-on N.A. engine?
Old May 28, 2006 | 04:36 PM
Sharif@Forged
Forged Performance
One step colder plugs can be used, but the chances of fouling a plug increase slightly...at least in theory. In practice, a typical NA car running 12.5:1 or 13.0:1 AF ratios is not going to foul out, even the 1 step colder Iridiums. Many track NA 350Z's are higher reving NA VQ35's will still run one step colder.
Old May 28, 2006 | 08:12 PM
Z350Lover's Avatar
Z350Lover
So Sharif,
what do you think I should run with my built N/A engine (I haven't got any iradiums yet)... Nismo puts #7, is that stock range or a step colder already?
thanks!
richie
Old May 28, 2006 | 08:28 PM
TiPIACE's Avatar
TiPIACE
think thats two steps colder than stock Rich
Old May 28, 2006 | 10:05 PM
Z350Lover's Avatar
Z350Lover
Sam,
you serious?! I suppose to use those #7 though...
cheers,
richie
Old May 29, 2006 | 06:04 AM
Sharif@Forged
Forged Performance
Originally Posted by Z350Lover
So Sharif,
thanks!
richie
7 is normal heat range. 6 is one step colder than stock.
What is the compression ratio, and intended rev limit of this engine?
burglapfd
Dec 6, 2020 01:04 PM
350z82
Oct 1, 2015 06:25 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
35reilly
Sep 28, 2015 07:42 AM
