Super Offset Slammed Pics - Can it go any lower?
Old Mar 30, 2006 | 06:32 PM
drumma022's Avatar
drumma022
Default Super Offset Slammed Pics **Update Pics Page 3**
Here are a couple of new shots today after lowering my car even more with the new coilovers! The new fender to ground clearance is now 24 1/8"(F) and 24 5/8"(R)!! I plan to raise it up to around 24 3/4" or 25" all around since the front fender wells rub around 85% of the low speed turns.
19x9.5 +11 235/35/19
19x10.5+11 265/30/19
Old Mar 30, 2006 | 06:34 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
that nothing. I can't even put my finger in the rear. Koni shock and Eibach spring.
Attached Thumbnails Super Offset Slammed Pics - Can it go any lower?-slam.jpg
Old Mar 30, 2006 | 06:39 PM
wooochang's Avatar
wooochang
neener neener neener bubble has your *** beat
Old Mar 30, 2006 | 06:40 PM
B-Unit's Avatar
B-Unit
low as fack
Old Mar 30, 2006 | 06:44 PM
drumma022's Avatar
drumma022
rear isnt a big deal ... with rolled fender and 265, possibilities are endless ... front is a bit harder to work with
Old Mar 30, 2006 | 06:46 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
back to you question, YES you can get them lower.
I'm going to change my front to 265. Are you doing the same? right now it is 255 and i think we still have some tiny room there.
my front now.
Attached Thumbnails Super Offset Slammed Pics - Can it go any lower?-slam2.jpg
Old Mar 30, 2006 | 06:49 PM
MCopare's Avatar
MCopare
Default mine a while ago...
pretty low
Attached Thumbnails Super Offset Slammed Pics - Can it go any lower?-low.jpg
Old Mar 30, 2006 | 06:54 PM
drumma022's Avatar
drumma022
did you modify the front fender-well at all? I am working with a 235 up front and cannot go larger due to the +11 offset.
Old Mar 30, 2006 | 06:55 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
the offset play very important role. My front offset is 24. Haven't touch the front fender yet. I'll have to roll or cut my rear fender when i upgrade to 305 in the rear.
255x35x20
285x30x20
Old Mar 30, 2006 | 06:58 PM
drumma022's Avatar
drumma022
I guess its time to install the CUSCO camber arms after all! Also calls for a title change of this thread Have any of you measure the fender to ground clearance for comparison?
Old Mar 30, 2006 | 07:00 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
the trick to give you better clearance when you drop your car and having body kit: Keep the front profile higher than rear. Guarranty you will not scrap your bumper.
I'll measure it tomorrow.
Old Mar 30, 2006 | 07:05 PM
Amiricanmade's Avatar
Amiricanmade
Looks Siiiiiiiiiick. How much lip do you have front and back?
Old Mar 30, 2006 | 07:06 PM
GQ 350z's Avatar
GQ 350z
Much props to drumma, I'm a huge fan of your car.
Lets just say you guys havent seen anything. Coming soon to a forum near you.
Old Mar 30, 2006 | 07:25 PM
B-Unit's Avatar
B-Unit
Ravi such a bling bling boy
Old Mar 30, 2006 | 07:31 PM
drumma022's Avatar
drumma022
any sneak preview ... or information leak to your super secret wheel fitment?
Old Mar 30, 2006 | 08:00 PM
GQ 350z's Avatar
GQ 350z
Won't beat your +11 =( but it'll be something of my own.
Ray, seriously much props. Can you send me some info on massive camber correction, such as the cusco setup and what you can do for me on them?
Much respect
ravi
Old Mar 31, 2006 | 04:42 AM
drumma022's Avatar
drumma022
Currently my car is 2 deg front and 3 deg rear camber ... but remember that toe is the most important variable to correct. As low as I am and using the Factory alignment adjustments, I was able to getthe toe back onto spec using these camber values. I will be adding CUSCO front camber arms so I can run 3 deg all around.
Old Mar 31, 2006 | 07:18 AM
mchong75's Avatar
mchong75
WOW, for that wheel setup...you're running on a bit small tires...exposing ur lips. From the pic...I could clearly see your wheel lips protruding out more than your tires. I'd be concern about curb rashes.
Old Mar 31, 2006 | 07:21 AM
GQ 350z's Avatar
GQ 350z
Werd up,
but with a ridiculous +11 offset, its the only way it will work. I'm pushing it with +17 rears, +11 is just rediculous.
My hats off to you, I'd be doing the same. I pray and pray to see the day sf winnings are offerred in like +13 or something like that.
ravi
Old Mar 31, 2006 | 07:22 AM
NA350Z's Avatar
NA350Z
Thats SICK!!
