DIY Parking Brake Handle replacement
Old Mar 23, 2006 | 08:52 PM
Anyone2u's Avatar
Anyone2u
Charter Member #82
Default DIY Parking Brake Handle replacement
UPDATE 07.08.16: Unfortunately the links to these pictures died a few years ago but fortunately I found them on an old drive and have re-uploaded them here. Be sure and read through the posts as there were some additional tips posted after I wrote this DIY up. Good luck!
I decided I wanted to replace my brake handle to match the interior theme of my car. Plus I had purchased both boots (shifter and ebrake) from Redlinegoods and it didn't look so great just sitting on top of the brake handle. I did a search on quite a few boards and couldn't find anyone that had actually replaced theirs so I decided to take it upon myself to figure it out.
Momo seems to have the biggest selection of brake handles and since my steering wheel, shifter **** and pedals were all Momo, it was the logical choice for me. I actually bought a couple of different ones before deciding which one to go with. Fortunately I was able to use one of the "extras" to help with this DIY. You also need to buy a Hand Brake Adapter (~$4) and you will need Model A2. This narrows the hole at the end of the brake handle where the button is.
Thoughts of just sliding the new brake handle over the leather should be discarded. Unlike the shifter **** (if you were able to get the stock one off without destroying it...), replacing the brake handle is a non-reversible mod as you have to remove the leather covering off of the handbrake, thanks to the Zs handbrake design. In addition you will need to buy a boot to cover the remainder of the car's handbrake. Again, I bought mine at Redline Goods and it fit perfect.
The tools are pretty simple: A dremel, a drill, a metal drill bit (I used 5/32" because that's all I could find in my tool box ) and a utility knife. A little allen wrench comes with most handles.
The Handle.This is a picture of a brake handle (Momo Pit Stop Red) along with some labels so you can make sense of what I am talking about as I explain the process. Note that the Boot Collar, which is plastic, slips on after you have the boot on. Unfortunately I didn't have a second boot so you'll just have to use your imagination for the time being.
Step 1-Destroying The Car's Handbreak. I used a utility knife and cut right along the seams. It hurt for a second and then I convinced myself that I could glue it back together if things didn't work out. Yeah, right... I also did a little trimming on the plastic "bottom boot" as well, after I slide the handle on for a test fit. Here's a picture of the "point of no return" stage.
(brake with handle removed)
Step 2 - Destroying The Handle Ok, since you have already destroyed your car's handbrake, destroying a ~$100 aftermarket brake handle is a walk in the park. Unfortunately the picture I took of the cutout on the actual handle didn't focus correctly so I had to use the extra handle to try and explain.
You must remove the bottom portion of the handle and it must be ~5/8" wide so that it clears the bottom portion of the car's handbrake that decides to "fans out" at the bottom. You also need to remove this section all the way back to the "Boot Ring", otherwise the handle will not be able to slide down enough to allow the brake button to stick out.
In addition you must also cut out a ~5/8" section on the plastic Boot Collar that slides on and holds the boot in place.
Step 3 - Destroying The Car's Handbrake (Part 2) Hopefully you did step 2 correctly so that the newly destroyed handle now slides down far enough so that the brake button sticks out far enough and is functional. Congratulations. Now, since you just removed one of the securing screws that holds the new handle on to the car's handbrake, and the one on the driver's side cannot be used since it would screw up the button mechanism (see picture below), you must drill a hole in the top of the car's handbrake and screw the securing screws into it. I used a 5/32" metal drill bit and the securing screw screwed right into very securely.
As the picture below shows, first thing you want to do is slide the handle onto the car's brake handle as far as it can go. Then mark the the point where you are going to drill the hole with something. You probably don't want to use the new handle's top hole as a guide and drill through it because you could screw up the threads inside the hole. I drilled right through the top of the handbrake to the other side and that didn't cause any problems. Here you go.
Step 4 - Attaching The Boot and Fixing The Boot Collar You Ruined Since you should have cut up the plastic Boot Collar, it will no longer hold the boot on so you now have to remedy that. I suppose you could use some superglue and glue the collar to the brake handle, but that may not stay. Since I had two extra securing screws left over (the one from the bottom that you removed and the one that should have gone on the drivers side but you cannot use since it would screw up the black brake assembly inside the car's handbrake) I decided to secure the collar to the brake handle by drilling two new holes 180 degrees from each other (using a clock analogy looking at the back of the handle, at ~10 and ~5 o'clock positions). Again, I used my 5/32" drill bit. After I drilled the holes, I put the brake boot on, slide the plastic boot collar back on and slowly tightened the screws down. Once the collar is secure, slide the handle over the handbrake and screw the two securing screws into the handbrake. BTW, the one on the passenger side (using the clock analogy, at 3 o'clock) needs one of the longer securing screws that you get with the handle kit. The other three securing screws are the short ones.
Step 5 - Final Assembly.After making sure that the handle is securely fastened to the handbrake (it shouldn't move at all) you can pull the boot over the hand brake and tuck it into the space between the handbrake assembly and the rubber piece that surrounds it. Speaking of the "rubber piece", you can see in my pictures that I removed mine, but I really don't think you need to do that. I was trying to figure things out and figured I would need to remove it. I still need to fix it but that's for another day.
That's it. Hopefully this works for you.
Old Mar 23, 2006 | 09:55 PM
vkzawa's Avatar
vkzawa
Holy Shiiet. Thats hot. Your a gutsy bastad. Nice whip man.
What is that ring on your speaker grill?
Old Mar 23, 2006 | 10:07 PM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
Wow that is definitely nice & excellent DIY instructions as well . Yeah, those pics of the cut-up OEM boot made me squint but it made me feel a lot better after seeing the last two pics. It definitely matches your interior nicely. BTW...what kind of seats do you have? Are those Sparcos? I want a black & red theme myself .
Old Mar 23, 2006 | 10:19 PM
jmcmorante's Avatar
jmcmorante
Darn I wanted to be done with spending $$$$ on this Z and now that I see ur interior makes me want to do something more. LOL !
Great JOB!
Old Mar 23, 2006 | 10:24 PM
DevineOrn's Avatar
DevineOrn
good job...i need new seats - my '03 Z's seats are starting to wear thing especially on the outer edges of the chair back where my body rubs on when i get in and out of the vehicle...i should have gotten leather...
Old Mar 24, 2006 | 06:55 AM
leemik's Avatar
leemik
Awesome looking mod!!! and thanks for the DIY... I think I might do this myself
Old Mar 24, 2006 | 07:43 AM
xtrememan315's Avatar
xtrememan315
You BASTARD! J/K! You do everything to your car that I want to do to mine, LOL
Very good write up and your interior looks hot!
Old Mar 24, 2006 | 07:53 AM
james840a's Avatar
james840a
you have a line to were you got the momo brake handle?
looks sweet, great job
Old Mar 24, 2006 | 08:13 AM
mdracer76's Avatar
mdracer76
WOW.. excellent write up! And it looks GREAT too!
I smell a sticky
Old Mar 24, 2006 | 09:35 AM
Anyone2u's Avatar
Anyone2u
Charter Member #82
Thanks for the compliments from everyone - really appreciated!
Originally Posted by vkzawa
...What is that ring on your speaker grill?
The front stock speaker setup is horrible in the car, so when Boston Acoustics installed the system they insisted on redesigning the speaker location in the door. It took the installer a couple of days to fabricate something that went with the car's brushed aluminum pieces.
Originally Posted by GTNPU Z
...BTW...what kind of seats do you have? Are those Sparcos? I want a black & red theme myself .
Sparco Monzas. They are a lot more comfortable and more supportive than the stock seats. Plus they are a little bit bigger than most other aftermarket seats.
BTW, I really like that gif in your signature!
I found LTBMotorsports.com had about the best prices, plus anything over $100 gets free shipping. As far as the brake handle that I ended up installing, it's only available outside of the US (Momo Italy not Momo USA)...
Old Mar 24, 2006 | 10:10 AM
james840a's Avatar
james840a
Thanks for the info, LTBMotorsports.com is were i got my momo shift boot at, it is very nice and goes with my black, silver momo AT shift ****. Ill check them out again for a brake handle. Ill check out Momo italy, i order stuff from over sea alot. My latest order is a custom tailored ankle length trench coat.
Old Mar 24, 2006 | 10:13 AM
leemik's Avatar
leemik
So Rog, If I wanted to order this e-brake handle:
http://www.ltbmotorsports.com/pitstopebhan1.html
I would also order an e-brake boot from redlinegoods.com
http://www.redlinegoods.com/order.sh...uct=350Zebrake
and this is all I need?
--mike
Old Mar 24, 2006 | 10:18 AM
james840a's Avatar
james840a
I think may need to order the adaptor for the momo e-brake.
Im going to order the other one, black and alum. with the black momo boot, from LTB motorsports
Old Mar 24, 2006 | 12:19 PM
Anyone2u's Avatar
Anyone2u
Charter Member #82
--mike
Yeah Mike, you need to order the adapter as well. The adapter that's supposed to fit our car is the A2 adapter . The only purpose of the "adapter" is to compensate for the differences in the diameters of the handbrake button and the new brake handle hole. I don't believe that it actually serves an important function with the exception of aesthetics and maybe keeping the button in the center of the handle. That said, I would definitely not skip buying it, especially since it's only $4.
As far as the brake boot, you would only need the brake one, just make sure it matches the shifter boot. Also you can use code Y3R52GY4U9 for a 10% discount until March 31st.
Old Mar 24, 2006 | 12:25 PM
Vamos_Rafael's Avatar
Vamos_Rafael
if its only $4 whats with the hassle to diy ??
Old Mar 24, 2006 | 12:26 PM
MyV6IsFast3r's Avatar
MyV6IsFast3r
Damn nice setup. Love that stearing wheel.
Old Mar 24, 2006 | 12:45 PM
G352NV's Avatar
G352NV
Ive been kicking this around for a few months now. You've pushed me over the edge!! Looks sweet!
Old Mar 24, 2006 | 07:26 PM
roncfpz's Avatar
roncfpz
Just had this done, but never thought about cutting out that bottom section. Excellent idea. I'll post some pics of mine soon.
Thanks!
Old Mar 24, 2006 | 10:34 PM
rbaggett1's Avatar
rbaggett1
Awesome interior man. That site you recommended has tiny photos. I found some bigger pictures. Who would have thought you could've gotten wood? LOL.
Wood
Aluminum
Chrome
Carbon
Airmetal
Red, Yellow, or Blue
Old Mar 25, 2006 | 12:39 AM
Z BOY's Avatar
Z BOY
great mod, great writeup. you're the first i've seen do this on a z. congrats.
