21HP 19 FT Torque! On the 350Z
Just thought I would share the product review with those all that are interested! Its a cold air intake system! Compare to others!
Click Below
http://www.afefilters.com/54-10482%2...z%20review.htm
Click Below
ROFLMAO! "With a retail price of $571.43 and an impressive power gain, this is a must have for the Z."
Would you get a load of the difference in torque. What the heck happened? The engine throw a rod out during the dyno? That's the most amazing piece of BS I've seen second only to that whirling piece of tin foil that is supposed to increase airflow in an intake.
Hehe, I think we need to set up a meet at their location just for shit's and giggles:
Advanced FLOW Engineering
191 Granite St
Corona, CA 92879
191 Granite St
Corona, CA 92879
CJ Motorsports
while its not likely that any intake itself could make those type of power gains... this one relocates the mass airflow sensor into its own tube. depending on the ID of their tube, and how the MAF is positioned, its possible to alter the tune of the car. For example, if the MAF housing area has greater flow then stock, then the car will run leaner. So its possible that the tune is being effected to make power more than the intake airflow itself is.
While thats probably giving this a bit more credit then due, its at least possible.
Click Below
Click Below
They also say you will wish that the rev limiter was set to 9000!!!!
Quote : Engine pick up is so strong it will make you wish the rev limiter was set to 9000 rpm. End Quote
And hold on, did they say they used a BRAND NEW 2003 Z? Where do you get a brand new 03 Z in 05?
See what they said about a neon SRT?
With a $20,000 price tag, a 230 hp turbocharged 4 cylinder engine, the Neon's image suddenly changed from "Cute Chick Car" to " The Fastest FWD Car in America". aFe knew the potential of this little rocket and decided the Neon SRT-4 was in need of an aFe experience. Lead engineer, Saul Zambrano, got a hold of a 2005 Dodge Neon and turned the Neon into a turbo beast with an additional 11 hp and 11 ft-lbs. of torque!
