3.5 Final Drive?
Old May 2, 2005 | 05:24 PM
jas142's Avatar
jas142
Default 3.5 Final Drive?
If I get an auto Z, where can I find a 3.5 final drive without having to go to a junkyard? Any websites sell them? How expensive is it, how expensive is the installation, and would I need anything else? (like a tune or chip to recaliberate speedometer, as you need on a Mustang when changing the rear-end gearing?)
Thanks!
Old May 2, 2005 | 05:31 PM
jkoc's Avatar
jkoc
http://performancenissanparts.com/ca...oducts_id=1962
something like this?
Old May 3, 2005 | 06:36 AM
PoWeRtRiP's Avatar
PoWeRtRiP
the 3.5 is the final drive from a stick shift. the auto has a 3.2? final drive. just swap the pumpkin from the rear between the two cars unless you really want to rebuild it.
Old May 3, 2005 | 07:56 AM
sentry65's Avatar
sentry65
the burninator
i have a 3.5 for sale...not the pumkin, just the gearing
Old May 3, 2005 | 03:02 PM
zzzya's Avatar
zzzya
This install is easy if you do a complete pumpkin swap, fairly expensive if you just do the FD gears. You do not have to do anything with the ECU or speedo since the 350Z uses sensors on the axles after the rear end and not in the tranny. It also has no negative effects on TCS, ABS or the cruise control just incase you were wondering. It is a great mod for the 5AT and really helps maintain a nice rpm after shifting.
Old May 3, 2005 | 05:06 PM
sigsauer87's Avatar
sigsauer87
yea, I was trying to get some information for this as well. What is a pumpkin? AHhhh....all of the confusion! haha...
Old May 3, 2005 | 06:26 PM
zzzya's Avatar
zzzya
The "pumpkin" is basically the entire rear end housing including the guts inside (FD, LSD, etc... The "pumpkin" bolts up to the drive shaft and the half axles. If you look under the rear of the car, you will see the "pumpkin" quite easily. The final drive (FD) is located inside the "pumpkin" and can be changed. The 5AT cars come with a 3.2 FD, the 6MT cars with a 3.5 FD and 350EVO makes a 3.9 FD. The entire "pumpkin" can be swapped from a 5AT car to a 6MT car and visa-versa, which will effectively swap the FD as well. One great mod for the 5AT cars is to find a rear "pumpkin" that has a 6MT (3.5) FD inside along with the stock VLSD. This makes the labor and install charge fairly low or zero if done at home. Many of the 6MT owners who track their cars are installing the 3.9 FD from 350EVO. The difference in the FD gearing being the lower the number, the slower acceleration will be but the higher the possible top speed in each gear. You want to balance the FD with the car's overall power output to the wheels. Those with TTs and SCs making huger power could benefit from a lower 3.2 FD because they have enough power to still accelerate blazingly fast, and the 3.2 FD allows each gear to make it to a higher speed thus decreasing time between shifting. In NA cars that aren't putting as much power to the wheels, the higher FD numbers will help them accelerate faster and maintain higher rpms in between shifts. The higher FD numbers usually yield lower gas mileage depending on the way the car is driven and where the engine is setup to make peak TQ.
Old May 4, 2005 | 10:01 AM
BluZee's Avatar
BluZee
I did a pumpkin swap on my Z and its bad ***. The install is very easy also.
Old May 4, 2005 | 12:17 PM
sigsauer87's Avatar
sigsauer87
thanks zzzya!
BluZee, How do you like the performance overall of your pumpkin swap (i finally know what that means lol). How much did it cost you, and did you go to the junk yard to get one? thanks.
-mike
Old May 5, 2005 | 11:42 AM
BluZee's Avatar
BluZee
thanks zzzya!
-mike
This is the best mod Ive done so far. First gear especially pulls a lot harder. I lowered my 1/4 mile time by .53 seconds.
I traded pumpkins with somebody who has a 6MT and wants to eventually get a ProCharger. I work in the service department at a Nissan dealership so one of the techs did the swap for free.
Old May 5, 2005 | 12:03 PM
roneski's Avatar
roneski
Half a second... wow. I can't wait to try mine.
Old May 5, 2005 | 12:49 PM
bwzabodyn's Avatar
bwzabodyn
see my thread I started today... I think 1/2 sec is not a reach at all...
Old May 5, 2005 | 01:27 PM
zachcrosen's Avatar
zachcrosen
Any thoughts of selling the pumpkin also yet??
Old May 5, 2005 | 08:29 PM
jlimquest's Avatar
jlimquest
I did a part search & came up w/ these two:
MT (3.538 ratio), exc. base model
MT (3.538 ratio), base model
Anyone knows what is the difference between the two? Which one would match an Enthusiast 5AT?
Old May 5, 2005 | 09:23 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
I'm assuming you got that from carpart. The difference is the pumkin in the base has NO lsd whereas all the other models do. Same ratios though
Old May 5, 2005 | 09:25 PM
blksnake's Avatar
blksnake
I beileve the first one has the LSD and the second does not.
1) MT (3.538 ratio), exc. base model
2) MT (3.538 ratio), base model
Old May 6, 2005 | 08:26 AM
bwzabodyn's Avatar
bwzabodyn
correct - if you are upgrading to an aftermarket LSD, the base model will be a cheaper alternative for you - however, if you are happy with the VLSD (or just want any kind of LSD like me) then the second choice is what you're looking for...
Old May 22, 2005 | 04:18 PM
only1's Avatar
only1
What are the advantages to the swap. I have an auto and might make a swap with someone. Any disadvantages to this for me? Also, does it matter that the other car as about 40k on it?
Old May 30, 2005 | 02:34 PM
Z ELIMINATOR's Avatar
Z ELIMINATOR
Default pumpkin 5 at to 6mt
I changed mine and it fells slower than the stock 5 at. I have a stage 3 stillen and the stock 5 AT pulled harder at 60 km . You can feel the difference in acceleration. At 6500 rpm it turns 152 km, while the stock one pulls 166.
will be going to the track next week and will post the times.
Old May 30, 2005 | 03:27 PM
zachcrosen's Avatar
zachcrosen
Did you ever hit the track prior to installing the 3.5 gears? I would like to see before (3.3) and after (3.5) runs.
