Another 350evo 3.9 Final Drive install
Hello,
I just got my car back from the shop. (Z Car Garage in San Jose) They installed the 3.9 final drive into my Z. While I haven't had too much driving time, the shop did some tests pre-3.9 and post 3.9. They used a g-tec meter. Main thing was to see any gains. Here is what they got.
Stock..
0-60
5.81
5.84
5.90
1/4 mile
14.47@104.9
14.49@104.3
w/3.9 drive installed
0-60
5.70
5.80
5.90
1/4 mile
14.08@106.6
I really like the 3rd gear pull the car has now! Can't wait to drive it more!
Stock..
0-60
5.81
5.84
5.90
1/4 mile
14.47@104.9
14.49@104.3
0-60
5.70
5.80
5.90
1/4 mile
14.08@106.6
If you want to see that 0-60 time drop (not that 0-60 means that much) get the rev limiter raised with the l-spec reflash. But Damn!! that is a nice chunk out of the 1/4 time. by the way what were the 60 ft times on those launches?? with that trap speed you should be mid-low 13's
Originally Posted by Armitage
Wow, 14.4 in a stock Z? What kinda 60' are you running?
In this example, the G-tech shows that he got a .4 second drop in the 1/4 mile. So, even if the actual numbers themselves are off by a lot compared to what he'd get at a real drag strip, the .4 sec drop is probably right.
Anyway, just thought I'd toss that in. I love my G-techs, but you have to be careful about how you evaluate the results.
Originally Posted by tacomaboy
a joke?
Originally Posted by OvaYahead
SJ when you have time can I get a ride in your z? as a passenger of course. I want to see how much of a difference the gear makes.
As far as the g-tec testing goes, it was just to see if there was any difference. Nothing more. The installer has a strip he calls "central raceway" where he does the testing. So, the road was the same and the weather was similar. Like I mentioned, it was mainly for testing purposes. There is a noticeable difference though. The more I drive the car, the more I like it!!
Originally Posted by zillinois
Actually, you can "see" the gains from final drive ratio change. If you map the old dyno over the new dyno plot using mph instead of rpms the results are quite impressive. I did this with my 3.5 to 3.9.
Extreme Dimensions
Southern California
09-24-2015 03:35 PM
