Anyone else have trouble filling up with gas?
When I try to fill up the pump quits on me like 4 or 5 times. I guess the gas is flowing too fast so it shuts the pump off. So I have to pump the gas real slow and it takes for ever. I can never tell if its completely full.
Are you guys experiencing the same thing?
I have tried pullling the nozzle out a bit, along with trying different angles but I still have to pump at half throttle.
Forgive me if this doesnt make sense, its 6a.m. here!
You know I didnt have the same issue, but the pump shut off the other day and when I got in the car after I had already left the station the gauge says I wasnt quite full. I need to verify next time I fill up.
A bunch of people were having this problem a few months ago. I haven't really heard much on it since. I've filled up four times so far and never had my car do that.
do i have some sort of super z.....or did they actually take time to inpect my car and put it together right....or did they just forget to put some care and effort into every other z out there???
i've NEVER had a problem filling up gas. i have NO tire feathering problems. i have NO streaking on the windows. i have ABSOLUTELY NO problems with my car. everything runs perfect and everything works. i guess i lucked out.
Veteran
I never had the problem, untill a few weeks ago... it has got to be the angle of the ground. all the gas stations I go to are level, but this one is sloped towards the gas door side. and I couldnt get more than half a tank in it. donno why or how, but just find a flat gas station and you should be ok.
if I remember it has to do with the new saddlebag design of tank they are using to lower the center of weight.
I have this sometimes. Major PITA. It took me 10 minutes one time to get a 1/4 tank, had to leave and get it somewhere else. I was woundering if it had something to do with the velocity that the pump can pump gas, maybe a bigger nossel opening? I have pretty much just found a station that I can fill up at without this problem and only get gas there if I can help it.
Filled up for the third time today. First time we were able to get 3/4 full before the pump cut off. Second time was no problem at all. Today, after about 1/4 tank, I couldn't get the thing going again.
I was filling up at Costco, and there happened to be an attendant there who took an interest in my car. Once he saw the problem I was having, he proceded to try all of his "tricks". Still no luck.
Finally, I tried turning the handle upside down, and bingo, I was able to get a full tank. I was concerned while I was filling that the shutoff might not work properly, but no problems there.
I hope this wasn't a fluke - I guess time will tell. The Costco attendant said my Z was only the third one he's seen, so he's looking forward to helping the next Z owner out!
Early Auto Gas Shutoff
Yep, Me too!
Filled the tank 15 times now.
Experienced the early shutoff problem 3 times.
I haven't been able to figure out why yet.
VIN #....4717
Lifting the nozzle slightly and pushing it towards the rear deck lid seemed to help - at least I was able to get a full tank.
VIN #....4717
Me also
Has happened to me also.
Last 2 times, left the gas station with 1/2 a tank - the next time I had 1/4 a tank. - Didnt realize it until I had already left.
This has never happened to me and I have filled up like 10 or 11 times by now 2200 miles. I was thinking about the gas pumps in florida that recover the gas fumes. It basically has a hose that fits over the filler hole along with the nozzle that fits inside. Could this be the issue? I dunno just a thought.
Originally posted by Jspec350z
This has never happened to me and I have filled up like 10 or 11 times by now 2200 miles. I was thinking about the gas pumps in florida that recover the gas fumes. It basically has a hose that fits over the filler hole along with the nozzle that fits inside. Most of you guys who seem to be having this issue are in a warmer climate that would probally have this device. Could this be the issue? I dunno just a thought.
I had a fill problem 2 times.The first time was near Tucson Az.The pump stopped around 1/2 tank.I think I had around 2000miles on the odometer.No other filing problems till 5000miles. Then,I drove my Z back to my lake house in Arkansas this week from Phoenix[7hours from Phoenix to Albuquerque N.M.,no radar detector]Anyway,I wanted to put a tank of 93 in,when I got to the house[91 in Arizona].So filled her up.The damn pump did not stop & gas came pouring out all over. I won't trust another pump.Just a little Xtra note:I do travel some & tour on my motorcycle quite a bit.ALL PUMPS ARE NOT EQUAL.I have had various problems while pumping gas in my H.D.Filling the bike is diferent from a car.You have to watch a little closer.Long story short.I've had pumps,not shut off,spray gas side ways,leak & dribble all over,& those stupid F**KING Calf nozzles pour gas every where.In closing,I am not sure if its a Nissan or a pump thing.But,from now on.........I will watch,look,listen.Thankz,Tom
