Post here only if you have had your TRANNY replaced.
Old Mar 8, 2006 | 12:13 PM
  #741
LIdrew's Avatar
LIdrew
Originally Posted by kardan350z
Transmission/Clutch Replaced at 29,000. VIN 2969 I developed 3rd gear grinding at 28,000. Have not had any problems getting Nissan to replace. Dealership got the replacement approved within 2 days of their inspection. They did not have a problem duplicating the problem. So, it's in for fix now....3/8/06. They indicated that this is a newly engineered, problem fixed(beefed up syncros) transmission. I hope so.
From what I've read the Newest tranny part # ends in 009. I had two 008's put in my 03 Z. Check the service order invoice. It has the part # on it. Hopefully it's the 009 Tranny.
Old Mar 9, 2006 | 10:13 AM
  #742
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
Getting mine replaced over the next few days. They FINALLY were able to duplicate the grind in third gear. I'm calling to verify the 009 version is being installed. This is the latest right?
Old Mar 13, 2006 | 11:47 PM
  #743
vallejomaan's Avatar
vallejomaan
6 speed replce on nov of 05 in wyoming , no 3rd gear, at 45k and now 5th gear pop out at 100mph+, at 54k i think i need another one
Old Mar 14, 2006 | 03:55 AM
  #744
bcheng4jc's Avatar
bcheng4jc
anybody still having tranny problem after getting 008 installed? i would think so since there's rumor out that there's a 009 tranny right?
Old Mar 15, 2006 | 03:53 AM
  #745
kardan350z's Avatar
kardan350z
Default New Trans-No 5th and 6th Gear 1st Day
Had my Tranny replaced at 29000 after 3rd gear grind. Picked it up yeaterday. They said they tested it. I have tried over and over.....cannot get it into 5th and 6th gear. It makes no movement and no sound when trying to push shifter to those gears. 1st "might" feel a little tight to get into, but 2nd 3rd and 4th feel great. Clutch feels fairly normal(new clutch also). Has anybody else had this same problem with the 32010-CD008 tranny?. Do these symptoms seem related to any linkage adjustments?. Before I talk to them again I just want as much information as possible so I can avoid them making excuses. I know there is the rumor of the newer revision part number...009. I would like to know if the 009 part is documented, and that it will fit on an 03. After checking this out more I realized I was pushing shifter too far to the right in the neutral zone, there is a notch there on the 008 trans. If I don't go that far to the right, 5th and 6th are OK.
I just gotta get adjusted to a slightly different shift pattern movement.
Old Mar 15, 2006 | 07:42 AM
  #746
NA350Z's Avatar
NA350Z
Yes it fits.
Old Mar 15, 2006 | 01:12 PM
  #747
showstoppertk's Avatar
showstoppertk
there is an 009 and yes it will fit 03-05 non rev-up motors, however I was told by my service dept that they will only put the 009 trans on 05-06 rev-up Z's. so they'll be replacing mine with an 008. I haven't heard anyone with problems on the 008 and no one seems to know the difference between the 008 and the 009 so I guess I'll just have to see what happens.
Old Mar 15, 2006 | 01:13 PM
  #748
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
They replaced my crappy '03 G35 tranny with an 008, no problems, the clutch is MUCH easier to push in. Although I burned the **** out if it the other day because I'm not used to it. So far no grinding, and the car even feels faster.
Old Mar 15, 2006 | 01:18 PM
  #749
showstoppertk
did they replace your clutch and pressure plate as well, or just the trans?
Old Mar 15, 2006 | 01:37 PM
  #750
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
Clutch too, I don't remember if they did the pressure plate, I would assume so. I can check tonight.
Old Mar 15, 2006 | 03:08 PM
  #751
Fa1rLadyZ's Avatar
Fa1rLadyZ
how can i tell if my transmission is bad or not? because sometimes its hard for me to shift from 1st to 2nd
Old Mar 15, 2006 | 03:18 PM
  #752
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
Mine ground when going into third. Especially during fast, low RPM shifts from second to third.
Old Mar 15, 2006 | 04:52 PM
  #753
showstoppertk
if you have to ask, then your trans isn't bad (yet). the most obvious sign with the Z trans is a 2-3 or 4-5 grind. its usually evident when the trans is cold or on high RPM shifts, but it isn't something you can miss.
Old Mar 16, 2006 | 07:16 AM
  #754
kardan350z's Avatar
kardan350z
What you guys mean by "008 will fit 03-05 non "rev-up" motors"? "Rev Up'????
Old Mar 16, 2006 | 11:26 AM
  #755
showstoppertk
008 refers to the model of trans. supposedly there have now been 9 revisions to the trans that they hook up to the Z/G since production. the 009 is the most recent model of course, and they supposedly use it in all current model "rev up" Z/G's. rev up would refer to the 300 hp VQ engine that was available in the 05 track, grand touring and anniversary model Z's as well as all 2006 MT Z's and G's.
Old Mar 16, 2006 | 11:32 AM
  #756
kardan350z's Avatar
kardan350z
I hope my new 008 tranny holds up.....
Old Mar 16, 2006 | 12:05 PM
  #757
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Had mine replaced.
I hate the new one.
Hard to shift. Chunky. Not symetrical.
Sucks.
Old Mar 16, 2006 | 01:01 PM
  #758
showstoppertk
Originally Posted by Hydrazine
Had mine replaced.
I hate the new one.
Sucks.
eek. I hope mines doesn't turn out like that. are you running a synthetic trans fluid?
Old Mar 16, 2006 | 06:26 PM
  #759
Hydrazine's Avatar
Hydrazine
Oooops!
Sorry guys. I should have clarified. The replaced transmission was in my 2004 G35.
The transmission in the new 06 Z is absolutely awesome. Smooth and symetrical. Shifts perfectly!
Now I hope it stays that way!
Old Mar 27, 2006 | 01:34 PM
  #760
zman2's Avatar
zman2
Just had 2006 transmission installed on my 2005 Z.
So far - so good.
Yes, there is a 009 part # transmission.
