RPM signal with Zeitronix
Have ZT-2 running with AFR, EGT, Boost and lambda where do i splice from to get the RPM signal (for connecting to Zt-2 green wire, pin #3).
I've seen a thread on this recently but can't find it now
Post any wiring diagrams you think might help
Check out this thread: http://g35driver.com/forums/showthread.php/t=40388 It has been a long time, but you might also go back and check some of my previous threads/post on Zeitronix. Looking through some notes I think it is terminal #62 Yellow/red wire on the ECU harness connector. That's assuming Nissan hasn't changed things.
Thnx guys. Any issues splicing off that wire and thus changing the impedance of the circuit i.e. knock-on effects elsewhere.
Does the wire (on pin #62) have a particular name
MAsSIVrOOM
10-20-2023 10:50 AM
etkms
06-19-2022 06:30 PM
Justin100
11-29-2015 03:58 PM
hardwood66
09-08-2015 04:31 AM
