Broke Oil filled diff mount on rear cross memeber
Old Jun 1, 2007 | 06:08 AM
VandyZ's Avatar
VandyZ
Default Broke Oil filled diff mount on rear cross memeber
Has anyone else seen this happen? It does not vibrate or anything, I just happened to have my car on the lift last night to replace a busted Y-pipe and noticed the FRESH oil on the cross member and exhaust pipe. It seems it had just ruptured.
According to Nissan it is not a replaceable mount, unless I get a complete rear cross member assembly.
5 years old, 73,000 miles and little things have just starting popping up.
Old Jun 1, 2007 | 06:14 AM
John's Avatar
John
The differential bushings are rubber, not oil filled. You sure your diff fluid didn't puke out of the breather tube? That does happen... otherwise you can replace the differential bushings - suggest you look at what www.splparts.com has to offer. Unless of course you're referring to a CV boot explosion (those are nasty)...
Old Jun 1, 2007 | 06:35 AM
VandyZ's Avatar
VandyZ
I wish I had taken a picture. It was coming directly out of the bushing. it trailed right out down the cross member and dripped onto the B-pipe of the exhaust.
Old Jun 1, 2007 | 06:37 AM
VandyZ's Avatar
VandyZ
just saw this on their site
The stock bushings also do not last long under such conditions, the rear bushing has a tendency to rip and leak.
Thanks for the link tho!!! I will have to pick one or all of those up.
Old Jun 1, 2007 | 08:14 AM
johnlotusboy's Avatar
johnlotusboy
I have also seen the stud hole in the cover crack and have oil running down the stud.
Old Jun 1, 2007 | 08:59 AM
VandyZ's Avatar
VandyZ
Wow, I will check that out. Thanks for the heads up.
2 Johns, 2 Lotuses? LOL.
Old Jun 1, 2007 | 06:00 PM
InZomniac's Avatar
InZomniac
I assume you speak of the round mount visible above the GT bace in the aluminum chassis work ABOVE the diff?
I have seen a few of these go out. You can buy just the piece but you must remove the entire assembly to replace it unfortunately. I would replace it due to the extra wear it causes on the drivetrain by not absorbing shock.
Old Jun 1, 2007 | 06:08 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
Those bushings are silicone filled and when they bust a very thick almost gel will leak out and everything sticks to it, making it hard to track where it comes from but best way to tell is poke your bushing with a extension or screw driver it should be firm and give very little if its in good shape if its in bad shape it will either ooze out more silicone or it will become very soft.
Old Jun 2, 2007 | 02:02 PM
Q45tech's Avatar
Q45tech
Silicone filled bushing in tension rods and rear subframe have been a common item on Infiniti since 1989.
The rear subframes usually need replacing ~~150k, however with modified suspensions and agresssive driving they obviously wearout faster.
Oct 4, 2015 07:55 PM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
Stevo Z
Oct 3, 2015 09:14 PM
Fixxxercask
Drivetrain
Sep 28, 2015 11:15 AM
