GT Motorsports Short/Long Blocks
Originally Posted by sugarspunZ
in terms of compression ratio why would one go with 9:1 vs 8.5:1 or 8.0:1 or anything else.
sorry if this is a newb question.
With a lower compression ratio you can run more boost and less timing, I'm guessing.
Ninja edit: http://www.tprmag.com/issue/6/6_forged_perf2.shtml <---Decent read
THis is the best there is for your cars...period.
I can't wait for my car to be done. I am sure Sam will do a write up on what we do on it.... insane stuff.
BTW.... with lower compression, you can run MORE boost (assuming the intercooling is unchanged) than you can with higher compression, and MORE timing advance, NOT less (assuming everything else remains equal).
Additionally, with lower compression and a little more boost, comapred with a higher compression and a little less boost, you can probably even run a little more timing in theory, as the AF mixture at the end of the compression stroke will be of lower temperatures in hte latter case.
The key is to pick the right compression for greatest efficiency possible (for situations that the car will be encountering).
Originally Posted by wtf no turbo
Sugar if your keeping your aps st I suggest a 9 to 1.
i am not looking for what CR i should run i am just trying to understand why some run 9:1 and others run lower.
still in the leaerning process.
and sorry to take the thread into a different direction. back on topic.
Great work GTM.
Originally Posted by Sam@GTM
The GTM extreme WISECO pistons are all costumes pistons made to our specifications, they are not the off the shelf piston that you can by from WISECO .in a matter of fact if you set the arias extreme next to our GTM WISECO piston you could not even tell the difference.as far compression ratio goes any thing you can think of we offer.
GT Motorsports
GT Motorsports
Originally Posted by captj3
Sam can you post the TSB # you were talking about earlier in the thread?
GT Motorsports
GT Motorsports
Hope this helps
,Sam
GT Motorsports
You can never have enough options or can you?
